Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-28-2011, 05:12 PM   #1
C5Natie
CF Senior Member
C5Natie's Avatar
Default Cylinder Head Help
Hey guys, I have some worn valve guides on my 215cc TFS heads. I was thinking of taking them in to get new guides pressed in. I was wondering what else should be done to the heads at the same time. Should I replace all the valves or just those that are no longer straight, and would this require new valve seats? I was thinking of ordering the parts from TFS myself. So far my list lists new guides, valves, and seats. I will be using the same springs since they are only a year old and the pressures check out. Am I missing something or are all those parts necessary? I dont need porting or milling and Im trying to keep costs down. Thanks.
C5Natie is offline   Reply With Quote
Old 08-04-2011, 07:21 PM   #2
mr.beachcomber
CF Senior Member
mr.beachcomber's Avatar
How many miles are on the heads? Just wondering if you've really got worn valve guides or worn out valve stem seals. It's not easy to wear out a valve guide except with a lot of miles or misaligned valve geometry especially with high lift cams or non-stock, high lift rockers.
I don't understand why the valves could be bent. Did you accidentally over-rev the engine at some point in it's life? Otherwise, they should be fine. With any high performance aluminum head, make sure that the block mating surfaces are straight. Mill if necessary.
While the heads are off, check all the valves for straightness as well as valve stem wear, and replace any valves that don't pass muster. Check the rocker arm studs for any unusual wear due to valve train misalignment. Then go ahead and check the valve guides for run-out with a good valve. If you need new guides, go ahead and have them installed. Refresh/do a three-angle high performance valve job on all the valves and their seats to maximize your airflow across the seats. Install new valve stem seals, and you should be good to go.
Hope this helps!
mr.beachcomber is offline   Reply With Quote
Reload this Page Cylinder Head Help
Tags
c4, cylinder, forums, head, install, time, vette
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
