bbc oil pan studs
bbc oil pan studs
Hi I am about to install some new moroso oil pan studs and was wondering if I should just put some oil on the studs, screw into block hand tight, then torque nuts to spec, or would it be wiser to put a dab of blue threadlocker on the stud, hand tighten into block, then torque nuts to spec. Opinons on this procedure welcome , thanks.
ikwhite
ikwhite
