Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-12-2010, 01:30 AM   #1
Chad7598
Junior Member
Default Casting Number / Engine Size
I recently bought a motor and I was told it was either a 283 or a 327 out of approximately a 1965 Vette. I've researched all the numbers I've found on the motor and all I can tell is that it might be a 327 or a 350 from the late 60's or early 70's. The main things I want to know is what year it is, what vehicle it was originally made for and what size it is (283, 327 or a 350)? ... Mainly the size though. Below I'm listing all of the number and places I've found them and see if anyone can decipher them for me. I wrote down the numbers as closely to what the appeared to be as possible.
I believe these letters/numbers were on the front of the block.
C4F415069
V03061JC
I think these letters/numbers were on the top of the manifold
340234 R
B274
These letters/numbers are on the back of the block
GM21
3970010
These letters/numbers are on the exhaust manifold
GM336710
These letters/numbers are on the block inside of where the bell housing mounts to the block.
010
020
509
H18
PS78
2 7/64
Chad7598 is offline   Reply With Quote
Old 03-13-2010, 04:02 PM   #2
mr.beachcomber
CF Senior Member
mr.beachcomber's Avatar
Default If the Block is Okay, It's a Keeper!
Quote:
Originally Posted by Chad7598 View Post
...I believe these letters/numbers were on the front of the block.
C4F415069
V03061JC
Can't help with the first number, but its' not a Corvette VIN. The second number identifies the block as a Flint, MI (V) engine built on March 6th (03, 06) with a vehicle application code of "1JC". (Couldn't fine that one anywhere.)
Quote:
...These letters/numbers are on the back of the block
GM21
3970010
The later number is the block number per se. In 1968 only, it was used for 327 engines while from 1969-1979, it was used for 350 engines in cars and trucks. I'm guessing you have a truck block from 1974. (Based upon the date code for the intake manifold which may or may not be original.)
Quote:
...These letters/numbers are on the block inside of where the bell housing mounts to the block.
010
020...
The first number indicates that the cast iron block has a content of 1% tin while the second number indicates a content of 2% nickel. I'm guessing that you have a 4-bolt main truck engine just because I haven't ever seen a 2-bolt main with both extra tin and nickel.
Here's site to a site with info on how to locate and read Chevy engine codes that might help. Good luck with your new engine!
Last edited by mr.beachcomber; 03-13-2010 at 09:22 PM. Reason: Added my reasoning for thinking that the block was fron 1974
mr.beachcomber is offline   Reply With Quote
Old 03-14-2010, 02:35 PM   #3
INMYBLOOD
CF Senior Member
INMYBLOOD's Avatar
http://www.nastyz28.com/chevy-engine-code-stampings.php
Look here. about half way down the page they get into the letters I just checked a block I have 3970014 T0501CNJ and the CNJ code was there.
My heads 3947041 High horse heads.... This is for sale as I am building another 350.
INMYBLOOD is offline   Reply With Quote
Old 03-15-2010, 12:13 AM   #4
Chad7598
Junior Member
Thanks for the info. I cleaned the engine more today and realized one of my letters were wrong. It was the one from the front of the head. I originally put V03061JC but the correct numbers/letters are: V0306TJC
Old 03-15-2010, 09:51 AM   #5
mr.beachcomber
CF Senior Member
...one of my letters were wrong...I originally put V03061JC but the correct numbers/letters are: V0306TJC
Using the link provided by INMYBLOOD, the "TJC" code translates to a 1973 4-bolt main 350.
Old 03-16-2010, 11:25 PM   #6
warriorp
CF Senior Member
warriorp's Avatar
010 casting block is a 350
warriorp is offline   Reply With Quote
Old 03-27-2010, 09:13 AM   #7
JMS71VETTE
CF Senior Member
JMS71VETTE's Avatar
Default Vin code
The GM code site I use shows this as a 1973 350, 160 base HP,4bbl,conventional cab C20-3500 Chev truck.http://www.nastyz28.com/chevy-engine-code-stampings.php
JMS71VETTE is offline   Reply With Quote
Reload this Page Casting Number / Engine Size
Tags
340234, 3970010, 3970014, 509, block, casting, chevy, gm21, head, heads, high, intake, manifold, nickel, numbers
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
