Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-03-2010, 09:31 AM   #1
INMYBLOOD
CF Senior Member
INMYBLOOD's Avatar
Default SBC roller cam help
Ok I'm building a old block and going to use a roller cam.
When using a roller cam is the thrust plate/washer necessary? It's not expensive I just wondered if it's built into the design to have it come forward the .03
INMYBLOOD is offline   Reply With Quote
Old 03-13-2010, 11:14 AM   #2
ZD1
CF Senior Member
ZD1's Avatar
A factory roller requires the plate to locate it fore and aft. Factory rollers have the cut/indent in the nose for the plate. The timing gear and plate hold the cam in place.
Nonfaxtory (retro) cams will still need the can button. You'll have to modify the a late model timing chain and/or block to make it work since the factory has a smaller bolt circle.
The best thing to do is order a Retro fit roller camshaft.
ZD1 is offline   Reply With Quote
Old 03-14-2010, 02:29 PM   #3
INMYBLOOD
CF Senior Member
INMYBLOOD's Avatar
Thanks That is what I did. Took a picture of the cam and sent it to a few friends and I think they were afraid to open the pic... I titled it "lovely Lumps"
Reload this Page SBC roller cam differences
Tags
block, cam, cams, corvette, factory, forum, gears, older, plate, retro, review, roller, sbc, thrust, timing
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
