Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-06-2010, 06:25 PM   #1
litevette
CF Senior Member
litevette's Avatar
Default HELP! What do I check first?
I took my '68 Firebird out for a spin today. Cranked up fine. Idled fine in the warm up, tapped the accelerator to lower the rpm's, backed out and off I went. When I got down the road, just a few miles, it wanted to die on me at the stop lights. As long as I shifted into neutral and kept my foot on the gas some, it would keep running. If I took my foot off the gas it would die. Where would you start looking for a problem? Fuel pump? Carb issue? Thanks in advance for your help!
litevette is offline   Reply With Quote
Old 02-06-2010, 08:33 PM   #2
litevette
CF Senior Member
litevette's Avatar
30 views and no replies yet. Anyone? Anyone?
Old 02-10-2010, 06:03 PM   #3
BogusSVO
Junior Member
BogusSVO's Avatar
how long has it been sitting?
what carb? maybe just the curb side idle stop screw moved some ?
have you done a vac reading?
BogusSVO is offline   Reply With Quote
Old 07-02-2010, 06:09 AM   #4
Mez
CF Senior Member
Location: Austin, Singapore, Kuala Lumpur, Houston, Dallas, Hong Kong, Elgin, etc.. Texas
Check the fuel filter.
Mez is offline   Reply With Quote
Old 07-02-2010, 11:54 AM   #5
427Hotrod
CF Senior Member
427Hotrod's Avatar
Sounds like it's lean at idle or timing is way off. Start with timing and then check carb. Not knowing the combo it could be:
Timing too low
Vacuum leak
Idle mixture set wrong
Cam requires more airflow and it's idling too low
Idle feed restrictions/air bleeds need to be tweaked (not as likely)
Give us more details. Carb, cam, cubes, converter, idle stop solenoid, A/C?
JIM
427Hotrod is offline   Reply With Quote
Reload this Page HELP! What do I check first?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
