Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-01-2010, 07:06 PM   #1
BogusSVO
Junior Member
BogusSVO's Avatar
Default How to check piston to deck clearance
The subject is a Toyota 2ZZ
The block is being milled to ensure a good gasket sealing surface.
The short block must be dry assembled with crank, rods, and pistons.
Rod and main bearings are installed, and only the 2nd ring installed.
The tools used are a dial indicator and bridge stand
Now zero the dial indicator on the block with .100 preload.
Next slide the dial indicator over the piston and rock the crank back and forth till the highest reading is found.
Now read the difference from zero to the depth of the piston.
In this case it was .004
It took .003 to square the block. Leaving the piston .001 in the bore at true TDC
BogusSVO is offline   Reply With Quote
Old 03-13-2010, 06:35 PM   #2
street62
CF Senior Member
street62's Avatar
Find top dead center with a dial indicator then see if the piston has any rock or movment on the wrist pin. Measure the closest point to the head with a depth mike. Measure the thickness of a crushed or used head gasket that you will be useing. If the piston is down from the deck of the block add that to the gasket thickness, if it is sticking out of the block then subtract it.
street62 is offline   Reply With Quote
Reload this Page How to check piston to deck clearance
Tags
1989, check, checking, clearance, clearence, corvette, deck, depth, height, indicator, measure, piston, todeck, tools
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
