Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-31-2010, 01:11 PM   #1
BogusSVO
Junior Member
BogusSVO's Avatar
Default How to lighten a stock cast iron Flywheel
How to lighten a stock cast iron flywheel
Start with your stock flywheel, In my case, 2.3L Turbo Ford
Its weighs in at 20.5Lbs
Lets see how much weight can be cut off….
Next is to remove the clutch plate alignment pins….
A slide hammer works well
Mount the flywheel upside down, on the flywheel grinder
Start buy cutting the excess cast iron down to the ring gear..
Once that was flush, I weighed the flywheel again, that reduced the weight by .75 lbs (12 oz) now 19.75 lbs
Time to thin the fat from behind the ring gear…
each pass, this machine cuts only .005-.008 off…
the final weight is now 17.75 Lbs
I removed a total of 2.75lbs…. This should help the engine rev a bit faster, with out giving up too much torque..
BogusSVO is offline   Reply With Quote
Reload this Page How to lighten a stock cast iron Flywheel
Tags
cars, engine, flywh, flywheel, lighten, stock
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
