High flow washable O.E replacement filter for your LS3 / LS7! In stock and ready to ship
Attack blue Performance filters are designed to allow your
engine to breath deep without sacrificing filtration!
It’ unique interwoven cotton media captures partials down
to 5 microns (human hair is 50 microns)!
Its Patent Pending low restrictive open design and narrow back, allows the greatest amount of air to rush through this filter with the least amount of turbulence over any O.E replacement filter on the market!
More free flowing air results in quicker throttle response, more torque & power to your rear wheels
Stock filters can clog fast resulting in a loss of power! Our cotton media helps keep your filter breathing deep longer. PLUS unlike stock filters, our new filter is washable & reusable which saves you money!
Fits perfect in your stock GM intake. Use your original filter retainer when installing
*Flow a whopping 45% more air then Stock!
*Patent Pending narrow back design helps eliminate “power robbing” turbulence!
*Quicker throttle response! Increase Torque! Gain over 4hp to the rear wheels by simply dropping it in!
*Filtrates down to 5 microns (a human hair is 50)!
*Washable and reusable for extended, reliable service!
*Improves Gas Mileage!
*Reinforced base prevents warping and leaks!
*Sturdy stainless mesh designed for high CFM.
*Fits perfect in your stock GM intake. Use your original
filter retainer when installing!
*Made in the USA!
Order online http://store.tkoperformance.com/tkohiflhipeg.html
Contact us if you have any questions 516 593 9093
