Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-29-2009, 10:39 AM   #1
BrianCunningham
CF Senior Member
BrianCunningham's Avatar
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
Default camshaft for a 327 in a C2
This is for member of my club
Quote:
I hope everyone has had great Holidays. I am looking for some suggestions on selecting a cam shaft for my 327 engine. The cylinders are bored 0.030 over and it has a small journal crankshaft. I am planning on replacing the cylinder heads with aluminum ones. The horse power I am looking for is 300 to 350. My plans are for street use. I guess I want a flat tappet, hydraulic lifters, with roller rockers. So I am looking for some guidance on selecting a cam as far as lift and duration. Suggestions on manufacturer and supplier will be helpful as well.
more info
Quote:
I have a Muncie 4sp close ratio transmission: 1st – 2.20, 2nd – 1.64, 3rd – 1.28, 4th – 1, reverse 2.27-1. The rear differential gears are 3:55.
The compression ratio is 10:50
__________________
Polo Green 95 LT1 6-spd
383 LT1/Vortech Supercharger/AFR heads/Rod end suspension/Penske-Hardbar dual rate coilovers/Wilwood 6pot brakes
NCCC Governor/Membership/WebMaster: www.baystatecorvetteclub.com
BrianCunningham is offline   Reply With Quote
Old 12-29-2009, 08:20 PM   #2
64_365
CF Senior Member
64_365's Avatar
http://www.compcams.com/Cam_Specs/Ca...?csid=110&sb=2
64_365 is offline   Reply With Quote
Old 01-02-2010, 05:02 AM   #3
gkull
CF Senior Member
gkull's Avatar
crane 272 with 1.6 RRs
http://www.cranecams.com/?show=brows...tType=camshaft
gkull is offline   Reply With Quote
Old 01-09-2010, 11:40 PM   #4
trmnatr
Junior Member
Quote:
Originally Posted by gkull View Post
You can run the above Crane cam and make the HP with the correct parts
I myself would go for 291 Camel Humps or 461's bowl ported and polished exhaust runners
With a set of -291 heads bowl ported and polished exhaust runners we are making ~530hp on a flat tappet 406 with stock crank, stock block, i beam rods and flat top pistons
Its all about properly setting everything up
trmnatr is offline   Reply With Quote
Old 03-05-2010, 02:32 AM   #5
cuisinartvette
CF Senior Member
St. Jude Donor '05
,,,good cam
Isky 270 mega cam would work great also.
cuisinartvette is offline   Reply With Quote
Reload this Page camshaft for a 327 in a C2
Tags
327, c2, corvette, mods, performance
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Engine Modifications that look Stock? mikeyandem C1 & C2 Corvettes 11 01-28-2005 02:23 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
