Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-12-2009, 03:14 PM   #1
Sliding
CF Senior Member
Sliding's Avatar
Default Solid roller for street
I've been reading a lot for last couple of days about solid roller cams
and more important about solid roller lifters and their premature wear
or failures when using them on street engines.
I know about pressurized oiling systems and even newer style lifters,
like Isky e-z roll, that don't have needle bearings.
What I'd like to know and hear from you is what is your opinion on
using solid roller on street.
Some manufacturers even name their series of camshafts as "street
rollers", so how big cams would fall into that category?
Sliding is offline   Reply With Quote
Old 12-23-2009, 03:54 PM   #2
jackvette911
CF Senior Member
CompCams solid rollers on the street are ****. Ruined 2 engines because of them. Nothing but Crower for me now. Running over 600 lbs open pressure and no problems for 6 yrs on same lifter now.
jackvette911 is offline   Reply With Quote
Old 02-12-2010, 12:32 AM   #3
warriorp
CF Senior Member
warriorp's Avatar
idle time is the hardest thing on a mechanical roller cam...i would consider forced oiling lifters a must...there are mulitiple types of cores the cams are ground on...its one of those things where you get what you paid for...some cheap street rollers are not even ground on billet steel cores, definatly avoid those...there are also different grades of steel used on the billets so talk directly to the cam manufacture and they can help you pick the right cam...something else to consider is that mechanical roller cams use significatly more spring pressure than most hydraulics, so be ready to spend some serious jack on a high quality valve springs that will last any amount of time
warriorp is offline   Reply With Quote
Old 02-15-2010, 03:51 PM   #4
ralph
CF Senior Member
I've used a street roller for years without any problems and no signs of wear when i tore it down this winter.....and my cam is cast iron. I use a high quality lifter (overkill) with pressurized oilers and use a profile that doesn't need big spring pressures (neighborhood of 180/500).
__________________
Corvette Challenge Champion: 2002, 2005, 2007, 2010
"Satan" 406: 10.8 @ 124
ralph is offline   Reply With Quote
Old 03-13-2010, 06:23 PM   #5
street62
CF Senior Member
street62's Avatar
I have run a solid street roller for years and only had a problem once . I broke a rocker arm stud , lucky me I use a rev kit just for that reason, to keep the lifter in the bore. Also I don't have to have as much spring pressure at the valve. My lift is .550 , seat pressure is160 and open pressure is 500.
street62 is offline   Reply With Quote
Reload this Page Solid roller for street
Tags
big, c5, cam, cores, corvette, life, motor, pressure, roller, rollor, soild, solid, spring, street, valve
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
*AFR 215RR solid roller top end FS or entire motor aggiez28 C4 Parts for Sale/Wanted 30 09-23-2005 02:25 PM
Not exactly an A-B-A test of a flat tappet vs a solid roller..but still interesting.. 427Hotrod Engine Mods 19 06-16-2005 05:06 PM
Average street life of a Solid Roller cam? Corey_68 C3 Tech/Performance 24 05-09-2005 04:59 PM
Got a ticket for street racing..... bloodvette80 C3 Tech/Performance 154 07-16-2003 12:43 AM
Solid Roller cam advice. FRC2000 Engine Mods 18 01-30-2003 10:04 PM
Help me decide about going balls out with a solid roller for my 427 MTI ironblock. Mopar Jimmy C5 Tech 28 12-30-2002 12:47 AM
Solid Roller Cam - do you like it? ELEVENS C4 Tech/Performance 33 10-17-2002 01:05 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
