Quote:
Originally Posted by BLOCKMAN
Over 14000.00 dollars in parts !! what is so speicial about this 383 and what are you using for a crank rods and pistons that cost so much.
It says its all new but the intake and balancer look used to me!! We have never bought a new ATI blancer that had rusted bolts in it.
"I have a Brand New 383 Stroker Engine that I had Built a few years back"
Sorry if you did not read the first line of my thread, but here it is again, above..\\
At the time I built the motor, the parts were alot higher than now, the only time the motor has been ran was during a dyno appoinment..Its never been installed in a Car, truck, boat, plane, motorhome, lawnmore, leafblower, motorcycle, tank sence it was built for me...
Its a seasoned block, 4 bolt, lunati forged steel crank(rated over 1000hp), H-beam manley rods, ARP studs or bolts in the rods, I think studs for sure, but that can be checked pretty easily, the pistons are forged with a special set up for alot of nitrous and rings, I cant remember the name brand of the pistons, Not Ross, Eagle or......????? The name was just capital letters??? sorry...
The block & heads are o-ringed, almost all the machine work was done by Gene Fulton, of Fulton Racing Engines,
http://www.fultoncompetition.com/...the heads and intake was done by a guy at Clements Racing Engines-House of Power,
http://www.clementsracing.net/, and a great engine builder in my area by the name of "Jimmy Hall" did all the work...
