Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-13-2009, 09:07 PM   #1
cardo0
CF Senior Member
cardo0's Avatar
Location: So Cal- - Defend your ideas with facts. Not personal attacks.
Default Realistic full duration numbers for GM hyd roller cams?
Where can i get full duration numbers for Chevy hyd roller cams? GMPP catalog lists just the 0.050" duration numbers for duration. GM uses a odd lift value for the open/close valve lift to determine full duration. I recall GM cams have real long/slow rise initial ramps - for longer cam life - and are hard to compare to most aftermarket cam full duration numbers.
Looking at GMPP "hot cam" for the 350 but can't figure overlap without full duration numbers.
Anyone have a source for full duration on Chevy hyd roller cams?
cardo0
cardo0 is offline   Reply With Quote
Old 09-14-2009, 12:15 PM   #2
mr.beachcomber
CF Senior Member
mr.beachcomber's Avatar
Here's a link to the best info I've found on the LT4 Hot Cam; however, it really doesn't have the information you're looking for.
Based upon my experience with Chevy racing cams in the 70's and 80's, you wouldn't be able to discern much information even if you had their full cam specs as Chevy uses clearance ramps in their valve timing calculations. These ramps lift the affected valve gently off its seat. While looking good in overall duration, there is little flow hence the use of the industry standard lift @ 0.050" to determine actual cam duration for comparison with other aftermarket cams.
I, too, would be interested if anyone has actually measured the intake and exhaust lobes of the LT4 Hot Cam to see how much meaningful area there is under the cam's intake/exhaust profiles. So far, I haven't found a reliable source yet.
mr.beachcomber is offline   Reply With Quote
Old 09-15-2009, 08:08 PM   #3
Curveit
CF Senior Member
Curveit's Avatar
The figures I got from my older GMPP are different than what mr . beachcombers' site lists, to further confuse things. Mine says...279/287- 218/228 @ .050, .525" w/ 1.6 rockers, and 112* lobe centerlines. If you're good at Math and my numbers are right, you might be able to figure it out. It is a fairly slow acting Cam, and I think you could do better at Comp Cams. For the same .050 numbers, a smaller "total" Duration number will idle better as well as picking up the bottom-mid range power, without losing any top end.
Curveit is offline   Reply With Quote
Old 09-16-2009, 03:47 PM   #4
cardo0
CF Senior Member
cardo0's Avatar
Default Thats good cam info.
Thx for the Hot Cam info - that just what i wanted. I read 'bout 53* overlap for the "Hot Cam" which ain't a whole lot. I don't think i can use the same intake ramp duration (62*) to 0.050" and exh ramp (53*) to 0.050" and just add it to other GM hyd roller 0.050" duration to get even a representative/useful number.
I would like 0.006" lift info for the "stock" LT4 cam and the "stock" LT1 cam(s) 0.006" info would also be nice but not totally nessesary. Trying to get an idea of how much overlap i can use and still pass smog. Yes i know the "Hot Cam" is not street legal.
Sorry for the late reply,
cardo0
__________________
74 T-top, L-48, 4spd, A/C, narly blue. Goodwrench 350 underwent new heads (SR Torquers), Schneider solid cam and Thorley headers due to domino effect of broken motor mount >broken fan shroud>remove radiator & A/C package. Now runs a Performer Air Gap with a lars majic chokeless Qjet on top. Also Street dampner, MSD dist, 6AL and Baster II.
http://members.cardomain.com/cardo0
Old 11-03-2009, 08:03 PM   #5
cardo0
CF Senior Member
cardo0's Avatar
Default Found more info.
From this link: http://www.grandsportregistry.com/lt1vslt4.htm
Numbers are a bit suspect as they list LT1 & LT4 cams with larger intake durations than their exhaust duration (typo i hope) and i don't agree with what they have for overlap numbers either - only 41* for the LT1 and 46* for the stock LT4 cam. Also, their LT4 full duration numbers are larger than the LT4 "HOT CAM" duration numbers so i don't know where they got their cam info or whether they use 0.006" lift for full duration?
Still looking,
cardo0
Old 11-09-2009, 10:33 AM   #6
ellewood
Junior Member
mr.beachcomber the link provide by you gave me the information
as much as possible about Where can i get full duration numbers for Chevy hyd roller cams.
Thanks a lot.
http://www.limos-la.com
ellewood is offline   Reply With Quote
Reload this Page Realistic full duration numbers for GM hyd roller cams?
Tags
california, cam, camshaft, chevy, corvet, duration, gm, hot, legal, lt, lt4, motor, numbers, smog, specs, street
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
