Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-07-2009, 02:41 PM   #1
ZLX
CF Senior Member
ZLX's Avatar
Default GM Mercruiser question
I am putting an Iron Duke 4 cyl in a flat fender jeep.. I love the little Iron Duke.. 3in stoke x 4 inch bore.. Pontiac 301 rods..
Mercruiser used the Iron Duke for a number of years as an I/O power unit.
I have noticed a 3.0 Mercruiser 4cyl of the same vintage.. bore is the same but stroke is 3.6 ... is this a stroker Iron Duke?, or a different block?...
3.0 Mercruiser info is not plentiful on the net... was curious about stroking my Iron Duke..
I realize this is a tad O/T.. just can't find good info on the 3.0 merc.
Anyone have info on the 3.0??
ZLX is offline   Reply With Quote
Old 09-10-2009, 02:27 PM   #2
rklessdriver
CF Senior Member
rklessdriver's Avatar
The 3.0L is a totally different block.
It has a SBC bellhousing pattern.
Few other dofferences in it and the 2.5L Iron Dukes.
The 3.0L uses a SBC (1pc) crankshaft flange and bolt pattern.
The 3.0L uses an odd ball 1.036" width rod that is 5.7" (stock SBC) long.
Being that the most common Jeep engine swap adapters are for a SBC, if you can find a complete good running fresh water 3.0L, IMO it would be a good and easy swap into an early M38 or M151 type Jeep. More power than a 2.5L but not near the imbalance of power and weight distribution that a V8 SBC would have in one.
Will
rklessdriver is offline   Reply With Quote
Old 09-24-2009, 05:29 PM   #3
Dale1990
CF Senior Member
Dale1990's Avatar
Will
Good info! I have Four Winns runabout with a 3L and I was always a little curious if it was related to the 2.5. Now that I know it has the same Bellhousing crank bolt patterns I might be in trouble.
Dale1990 is offline   Reply With Quote
Reload this Page GM Mercruiser question
Tags
25, 30, 30l, duke, flatfender, gm, iron, mercruiser, mods, performance, power, rods, sbc, stroker, swap
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
LS6 v LT5 question jimmy2004 C5 Z06 Discussion 87 06-18-2004 11:46 PM
Street Skinner? dennismont C4 ZR-1 Discussion 21 11-17-2003 02:52 PM
Carb Kit on an LT5? TIMSPEED C4 ZR-1 Discussion 12 04-24-2002 07:11 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
