Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-20-2009, 12:23 PM   #1
rahaul
CF Senior Member
Default Need help....grooving hyd. roller lifter cases
I understand that oil flow to the rollers can be improved by grooving the case to allow oil to flow directly to the rollers. I don't need to know how to make the groove. I'm just not sure where. These are Morel lifters.
Also, Is 1/2 turn past 0 lash good for valve adjustment?
Thanks in advance.
rahaul is offline   Reply With Quote
Old 08-23-2009, 04:20 PM   #2
427Hotrod
CF Senior Member
427Hotrod's Avatar
Grooving the case is only going to spray the oil onto the wheel. It won't necessarily get it into the needles where it's needed..but it can't hurt.
Take a look at the instructions for the Comp Lifter bore tool to gets some ideas on placement. Might be a lot easier to just do the bores?
http://www.compcams.com/Technical/In.../Files/170.pdf
Morels are typically a little louder, but rev well. Will likey take 1/2 a turn to keep them sorta quiet at startup.
JIM
427Hotrod is offline   Reply With Quote
Old 08-24-2009, 07:42 AM   #3
rahaul
CF Senior Member
JIM
I saw the Comp tool to groove the bore and also decided to go with doing the lifters. I'm hoping it will also get more oil to the needles.
Thanks for the tip.
Reload this Page Need help....grooving hyd. roller lifter cases
Tags
installation, lifter, pictures, roller
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
