Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-27-2009, 09:49 PM   #1
rahaul
CF Senior Member
Default Big Block rebuild....need some tips
Can anyone suggest a link for rebuild tips? It's a simple rering, rods, mains. Ate the cam/ lifters and trashed the engine. Last rebuild was me and Chiltons in 1996. Looking for latest/ greatest tips. I can dig the Chiltons back out if I have to.
Engine: '71 454 LS6 crate motor stock bore
balanced/ blueprinted
4 bolt / steel crank rods .20 mains .10
rectangle port heads
All GM except Bullet cam / Morel roller hydralic lifters
Street application
Also, in '96 I polished the alum intake and applied 2 coats of Eastwood Polished Alum clear coat. It looked great for 5 or 6 yr but slowly started looking tired. After stripping it I discovered the alum had actually begun to oxidize under the clear coat. Has anyone had better luck with anything else?
Thanks in advance
rahaul is offline   Reply With Quote
Old 07-28-2009, 04:31 PM   #2
Richard454
CF Senior Member
Richard454's Avatar
Send a message via AIM to Richard454
Here's a good book- at a Big Block price-$80+ but there are some used ones out there for $20+.
http://www.amazon.com/Modify-Chevrol.../dp/0760302030
It's next on my buy list.
Richard
Richard454 is offline   Reply With Quote
Reload this Page Big Block rebuild....need some tips
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Weights, measurements, ratios, strengths, etc leaftye C5 General 239 01-18-2012 04:29 PM
c5 coupes typically leaky? LSUgoTIGER C5 General 24 09-07-2005 11:24 PM
The beginning of the end prodigy467 C3 Tech/Performance 27 01-16-2005 11:19 PM
About to rebuild my 327 - suggestions? valrico_stingray C1 & C2 Corvettes 77 02-28-2004 02:05 AM
Sidepipe & header help and info needed! C1 & C2 Corvettes 28 12-09-2003 08:16 AM
Somewhat O/T - High-comp engines and todays gas with a story about a 442... Corellian Corvette C1 & C2 Corvettes 10 01-27-2003 09:56 PM
Q-Jet Problems and Tips lars C3 Tech/Performance 19 11-15-2002 01:05 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
