Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-11-2009, 10:46 PM   #1
Edgardoug
Junior Member
Default Broken ZZ 383
Shooting 150 hp of NOS (plus a detonation event) I blew a piston of my ZZ 383. This crate engine got hyperetectic pistons ... I knew they were the weak link among this engine internals.
Now I want to step up and install a good set of forged pistons. But it turns out GMPP installed a "Special" stroke crank shaft with a stroke of 3.800 (not the common 3.750). Where can I find pistons to go with this crank? Rods are 5.700
Edgardoug.
Edgardoug is offline   Reply With Quote
Old 07-12-2009, 09:12 AM   #2
BLOCKMAN
CF Senior Member
Edgardoug.
Your probably looking at a custom piston for the stroke combontion.
BLOCKMAN is offline   Reply With Quote
Old 07-12-2009, 07:22 PM   #3
427Hotrod
CF Senior Member
427Hotrod's Avatar
Or some regular *383* pistons. They are for a .050" shorter stroke. Your pistons are likely .020-.025 down in the hole anyway.....maybe use 383 ones and mill the tops a little to end up with .000-.010 OUT of the hole. Then use typical .040 or so gasket to end up with really nice quench with no need for block decking.
Check compression heights...you'll also find that many replacement pistons are *short* anyway to allow for decking and you might find what you need with careful measuring.
JIM
427Hotrod is offline   Reply With Quote
Old 07-13-2009, 01:31 AM   #4
billla
CF Senior Member
Support Corvetteforum!
billla's Avatar
Send a message via MSN to billla
Custom pistons aren't all that much more expensive than "off the shelf" any more with CNC machining. With many companies you can even say "I want a piston like P/N xxxxx, but with a compression height of 1.375". Talk to your machine shop; they've got books for miles and smarts to see if there's anything off the shelf - or to tell you who they'd prefer to order the customs from. Remember - your shop has to make them work; don't walk in with a box of pistons and say "here".
I tend to stick a little short of a zero deck, but I'm a conservative builder. You do want to shoot for that magic .045 quench since you're doing all this work. IMHO I would not take a huge deck cut when you can get the right deck height in the pistons. Cutting the deck significantly will cause problems with intake alignment. You'll need to get the intake cut for sure...and you'll definitely want to look at the port alignment as well if you go that way.
I agree it's kind of an odd approach for GMPP - I understand wanting to keep a 4.00 bore (new block) but why not stick with a "standard" 3.75 stroke and just give up the lousy *6* cubes???
billla is offline   Reply With Quote
Reload this Page Broken ZZ 383
Tags
383, corvettes, crate, engine, install, pistons, review, reviews, sale, zz
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
