Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-05-2009, 01:00 PM   #1
upnorth
Junior Member
Default carb question
i have a 350 that i worked on years ago . but was never happy with the carb . its a r8 4010-1 the engine is bored over 30 decked 40 has a 350/350 kit with dart 65cc heads torker intake and crane roller rockers its also balanced . when i did a compression test years ago it averaged around 220 .in about 15 years ago that i built the engine it has about 3000 miles on it . but if you jump on it it seems like it runs out of gas . has electric fuel pump and is set at max around 5.5lbs .i havent played with it in years so theres probably more that ive done to it that i dont remember .
upnorth is offline   Reply With Quote
Old 07-14-2009, 12:46 PM   #2
mr.beachcomber
CF Senior Member
mr.beachcomber's Avatar
Default Bog Or Loss Of Power?
Quote:
Originally Posted by upnorth View Post
...if you jump on it it seems like it runs out of gas...
Are you bogging down under acceleration or just losing power as you accelerate? If you're bogging down, check the accelerator pump shot to make sure it's working. (The pump should tip in fairly quickly as you open the throttle.) Also check the electric fuel pump to make sure you still have at least 5.5 psi at the carb's fuel inlet all the time.
If you losing power as you accelerate, make sure your accelerator pump shot isn't running out of gas after the initial tip in. Check the fuel pump pressure as outlined above, and then check your initial (crank) timing as well as your timing advance as you open the throttle. (Chevys have a tendency to retard their timing if the distributor clamp loosens up with time.)
If the problem isn't the carb or timing, check your cam's timing. (You might have jumped a tooth or two on the cam sprocket under heavy acceleration if the timing chain was loose.)
Hope this helps!
mr.beachcomber is offline   Reply With Quote
Old 07-14-2009, 04:24 PM   #3
cuisinartvette
CF Senior Member
St. Jude Donor '05
I would monitor your fuel pressure under a load (acceleration).
Pump could be weak or just not able to keep up.
cuisinartvette is online now   Reply With Quote
Old 07-27-2009, 01:15 PM   #4
billla
CF Senior Member
Support Corvetteforum!
billla's Avatar
Send a message via MSN to billla
I'd be just about 100% certain that this is a tuning issue, and most likely a timing advance issue.
Use the timing sticky in the C3 Tech section to get your timing curve right, then circle back with tuning the carb
billla is offline   Reply With Quote
Reload this Page carb question
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Read my plugs & Carb Question. . . dath C3 Tech/Performance 26 08-29-2005 08:02 PM
Quick Barry Grant carb Question..Any Barry Grant users out there?? 68coupe C3 Tech/Performance 16 05-26-2005 02:59 PM
intake/carb question destroyoboy C1 & C2 Corvettes 9 05-06-2004 10:55 AM
Carb question - Secondaries do not want to open oprahrider C1 & C2 Corvettes 16 12-26-2003 06:33 PM
Intake/Carb Question Brian Matheis C1 & C2 Corvettes 9 01-24-2003 01:02 PM
Another carb question: Why is my idle all over the place? Shrike C3 Tech/Performance 13 04-10-2002 06:15 PM
Carb Question - lars Joe 80 C3 Tech/Performance 9 09-20-2001 06:19 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
