Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-02-2009, 07:14 AM   #1
94z07fx3
CF Senior Member
Default Fluidampr
Anyone using a Fluidampr harmonic damper?
What are your thoughts?
I have a 7.4 liter BBC in a Suburban and its harmonic damper seems to function ok but it has rust, age, and 200,000 miles on it. I was thinking of just putting a stock damper on it but when I was looking for one I ran across the Fluidampr and wondered if it could help the BBC in the smoothness category.
94z07fx3 is offline   Reply With Quote
Old 07-03-2009, 11:51 AM   #2
babbah
CF Senior Member
babbah's Avatar
I have a fluiddampr HB on my 67 BBC. Works flawlessly! No problems. Get one, and no more worries about your balancer. PS- They are not cheap!
babbah is offline   Reply With Quote
Old 07-03-2009, 02:09 PM   #3
BLOCKMAN
CF Senior Member
What's interesting about a fluid dampner you can't balance a crank with one as it will not repeat twice and it does through the rear off as well.
When you balance with a fluid dampner the outter ring has to be taken off.
BLOCKMAN is offline   Reply With Quote
Old 07-03-2009, 02:58 PM   #4
69427
69427's Avatar
Location: I tend to be leery of any guy who doesn't own either a chainsaw or a handgun.
Would you like to explain how that's done????????
69427 is offline   Reply With Quote
Old 07-03-2009, 03:57 PM   #5
BLOCKMAN
CF Senior Member
Quote:
Most fluid dampners are 2 peice design and on the BBC's we have balanced for other shops we have to take the otter ring to balance or it will never repeat on both ends.
Old 07-05-2009, 08:41 PM   #6
427Hotrod
CF Senior Member
427Hotrod's Avatar
At 200K in a suburban I'd just get a stock one.
Otherwise I lean towards ATI exclusively. Not too wild about the fluid ones unless its a very limited RPM range....like the diesels they were designed for.
JIM
427Hotrod is offline   Reply With Quote
Old 07-19-2009, 09:11 PM   #7
cardo0
CF Senior Member
cardo0's Avatar
Location: So Cal- - Defend your ideas with facts. Not personal attacks.
Default Thats hi-milage and the vlv train probly has plenty of slop.
The idea of silicone fluid in a dampner is to reduce timing chain scatter from the crank pulses. But with 200k mi your overdue for a new timing set (and cam if a flat tappet) already. A fairly more expensive Fluidampner would be an unnecessary expense. U would be better off using a inexpensive stock dampner and spend the difference in $$ to buy a new timing set.
On the other hand the Fluidampner's are not expected to wear/rot out like a stock elastomer dampner.
Hope this helps ya',
cardo0
cardo0 is offline   Reply With Quote
Old 07-20-2009, 07:32 PM   #8
cuisinartvette
CF Senior Member
St. Jude Donor '05
Cheap stocker, the way they can oscillate is a good thing in terms of crank twist, etc.
I dont know this for fact but I have heard of a few cases where, in freezing temps the Fluidampners have failed and caused damage due to the fluid freezing. True, who knows
With that said Ive used them on two different motors, happy with them .
cuisinartvette is online now   Reply With Quote
Old 07-23-2009, 01:06 PM   #9
Cstraub69
CF Member
I know of at least 3 crankshaft manufacturers that don't recommend fluid dampers. This technology comes from low rpm diesel applications where the dampers were matched to the rpm the engine would be running for most of its life. These engines recieved the same crankshaft and other components in which the damper was tuned for. A Bryant billet compared to an Eagle 4340 crank with the same stroke will not have the same harmonics.
Cstraub69 is offline   Reply With Quote
Reload this Page Fluidampr
Tags
bbc, c5, corvette, damper, dampner, fluid, fluidamper, fluidampr, forum, problems, product, review, reviews
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
ATI or Fluidampr for damper? Hell-bent C5 Tech 24 12-03-2004 12:46 PM
Fluidampr Installation 89vette C4 Tech/Performance 11 03-11-2003 10:22 PM
Fluidampr or Regular? ZD75blue C3 Tech/Performance 15 12-01-2002 08:09 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
