Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-19-2009, 12:13 PM   #1
Fast Freddy
CF Senior Member
Fast Freddy's Avatar
Default i bought a crate motor yesterday - cam experts come in
402 CI aluminum LS2 block with a forged 4.00" Callies crank and Forged Manley H-Beam rods/pistons. AFR 225 cc BIG bore heads that have 2.08 intake and 1.60 exhaust valves. they flow 320 cfm @ .600' lift on the intake and 250 cfm @ .600 lift on the exhaust. the compression ratio is 11.2:1
the cam is a comp cams hydraulic roller with .596 lift and a 114 LSA.
the duration on the intake is 250* @ .050 and the exhaust is 246* @ .050
so can anybody tell me what rpm this cam will make peak power at? i am guessing 7,000 rpm's
this motor is gonna be going into my '01 camaro SS. i am gonna run a 92mm fast intake and throttle body with 1-7/8" Hooker headers and no exhaust with just the straight 3" collectors. i am also gonna spray a 150 shot of nitrous direct port
__________________
2006 FORD GT - 751 rwhp/703 rwtq > gps'd 225 mph
2001 VIPER GTS (ACR) - 640 rwhp/703 rwtq > 183.63 mph @ the Texas Mile (15 mph headwind & 2500 DA)
2004 CORVETTE Z06 (Z16 Lemans Edition) > Just-a-Cruzer
2001 CAMARO SS - 447 rwhp/496 rwtq > 11.18 @ 122 mph (4000 DA)
2001 LIGHTNING - 430 rwhp/483 rwtq > 12.67 @ 108 mph (2100 DA)
http://youtube.com/user/FastFreddy488
Fast Freddy is offline   Reply With Quote
Old 06-22-2009, 09:36 AM   #2
mr.beachcomber
CF Senior Member
mr.beachcomber's Avatar
Quote:
Originally Posted by Fast Freddy View Post
...so can anybody tell me what rpm this cam will make peak power at?...
Talk with COMP Cam's Tech Support. They can tell you for sure as well as what compression ratio works best with the cam. You might let them know about your intended use of nitrous oxide to make sure the overlap in the cam isn't allowing most of your 150 shot to end up in the exhaust.
mr.beachcomber is offline   Reply With Quote
Old 06-30-2009, 09:34 PM   #3
Fast Freddy
CF Senior Member
Quote:
thanks
they told me that it is not a nitrous cam and it has a XE lobe. i am gonna put a nitrous grind in it with a XE-R lobe. should make peak power at or below 7,000 rpm's just where i want it
__________________
Old 07-03-2009, 06:00 PM   #4
Lt1er
CF Senior Member
Lt1er's Avatar
thanks
Your real problem is the H-rollers. Valve float will be the limiting factor.
I've been using Solids for years and with modern allen locking nuts on the rockers the minor chore of setting them is more of check because they rarely change.
The other thing holding your motor back is just a lack of CI. 250 intake on 400 ci makes for a radical motor when combined to high cfm heads.
Lt1er is offline   Reply With Quote
Old 07-05-2009, 01:42 AM   #5
MLCZ51
CF Senior Member
MLCZ51's Avatar
Default Thinking 2300 - 6800rpm..
MLCZ51 is offline   Reply With Quote
Old 07-11-2009, 12:52 AM   #6
mattsc
CF Senior Member
mattsc's Avatar
Hey ,I'm looking for a similar forged block .you happy with your and the pricing? what kind of $$ am I looking at??
Thanks,Matt
mattsc is offline   Reply With Quote
Old 07-23-2009, 01:08 PM   #7
Cstraub69
CF Member
Peak at about 6700 rpm. Just hope it has Morel lifters in it.
Cstraub69 is offline   Reply With Quote
Old 07-25-2009, 08:41 AM   #8
intoc6s
CF Senior Member
intoc6s's Avatar
Somewhat similar to my 427. Mine is 11.9 CR with a 252* 264* .647 .647 on a 110*. My heads are TEA Ported/polished/flowed L92s (262cc intake runners flow 348cfm @ .600) I would say without a doubt that your car will put down over 500whp NA. Probably closer to 550(without Nitrous) Especially with those heads. Probably be shifting @ 6700-ish. Do yourself a favor and(if its a 6 speed) break in your clutch properly.(ask me how i know....) $1000 mistake!... Good Luck! -Jason
intoc6s is offline   Reply With Quote
Reload this Page i bought a crate motor yesterday - cam experts come in
Tags
250cfm, 600lift, crate, fast, freddy, freddys, freedy, motors
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
