Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-27-2009, 04:48 AM   #1
devilfish
CF Senior Member
devilfish's Avatar
Default JEGS 197cc heads and rocker alignment.
Hi.
I use JEGS alu heads ( http://www.jegs.com/p/JEGS/JEGS-SB-C...50801/10002/-1 ) in my build.
I having a hard time to get intake vavle 3 and 4 to align center on the vavle tip. I got the tips to cut the guideplate, re-align the rockers and then weld it togheter.
Im not to found of that solution as im not a experienced welder, nor have i got a MIG/TIG.
My other ide is to get self-align rockers, and get rid of the guideplates.
So the qeustion is.
Can I use self-align rockers with those heads, if i take off the guideplates?
And will the use of self-align rockers mess up my otherwise good vavletrain setup ( push rod length etc )?
I whas thinking of these rockers.
http://store.summitracing.com/partde...5&autoview=sku
devilfish is offline   Reply With Quote
Old 05-27-2009, 07:56 PM   #2
Pete K
CF Senior Member
Pete K's Avatar
I forget who makes them, but there are guide plates that are split for the exact purpose you need them for. I think Manley makes them.
Pete K is offline   Reply With Quote
Old 07-03-2009, 02:18 AM   #3
gkull
CF Senior Member
gkull's Avatar
You can not use guide plates to force a push rod over to align the rocker arm. Correctly adjusted push rod guides never touch the shaft. Slight non centering is no big deal. When you get into heads that have wider or altered valve placement the fix is offset roller lifters or offset rocker arms
Do the heads have push rod clearance?
gkull is offline   Reply With Quote
Reload this Page JEGS 197cc heads and rocker alignment.
Tags
197, 197cc, alingment, cc, heads, jegs, rocker, valve
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
