Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-19-2009, 11:07 PM   #1
djZ06
CF Senior Member
Default LS7 oil pan
Does anybody know any aftermarket pans for the LS7 in lieu of stock (dry sump set up) Looking into A.R.E. but but seeing what else might be out there.
djZ06 is offline   Reply With Quote
Old 06-23-2009, 03:27 PM   #2
Pumba
CF Senior Member
Support Corvetteforum!
Pumba's Avatar
ARE has a replacement pan for the LS7. GM has been told that their LS7 dry sump system is a joke. ARE's pan is a first step in correcting the problem. You will also need a better / larger dry sump tank, etc.
Here is the URL to the pan - http://www.drysump.com/ls7.htm
__________________
Fidanza Dual-Disc Clutch - Liberty ZR1 Trans w/2.66-1.78-1.30-1.00-0.79-0.628 gears - RPM ZR1 3.42:1 Quaife Diff - L.G.M.: Trans&Diff
Coolers-Headers-Coilovers-CFiber D'Shaft - Pfadt Pfatty Bars - Mamo LS7 T'Body - TPiS LS6 intake - DRM Brake Ducts - ZR1 Carbon-Ceramic Brakes
Corsa Pro-Series Indy - SETRAB Oil Cooler - RD Radiator - DeWitts Fans - MCM Hood - Cafaro Spoiler - Tiger Shark Fascia - Carbon-Fiber Splitter
Pumba is offline   Reply With Quote
Old 06-23-2009, 06:13 PM   #3
Threshold
CF Senior Member
Threshold's Avatar
Speedyesx
Well for a street car on run flats it's pretty trick, that's what it was intended for if you want more it's on your dime. I guess GM never really expected anyone fast to put the car on a road course for any length of time without some simi-major modifications, those magazine articles were just for show.
Threshold is offline   Reply With Quote
Reload this Page LS7 oil pan
Tags
2009, aftermarket, c5, corvette, corvettes, ls7, oil, oilpan, pan, pans, problem, replacement, sale, stock, vs
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
$12,995 for a complete LS7 engine 2000Firehawk C6 Z06 Discussion 46 07-31-2005 07:24 PM
GM announcement on LS7 & other engine stuff Troy Roberts C6 Z06 Discussion 131 09-12-2004 12:23 AM
Stock Oil Pump or High Volume Pump for '85 Bluevette85 C4 Tech/Performance 48 10-10-2002 09:53 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
