Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-19-2009, 01:12 AM   #1
ZD1
CF Senior Member
ZD1's Avatar
Default leaky valve cover afr or risque pcv breather?
I have a newly running 427ci SBC. It has a MAJOR oil leak, which prevented me from doing any dyno runs. But after putting two qts of oil in, I was able to drive it home.
The heads are AFR, which I have heard to have puddling problems near the outside corners. was there any fix to this?
I went with a hard MrGasket valve cover gaster vs my normal hitech silcone ones dry. Should these be used? Should I use sealant (first ever for me)?
The valve covers are tall al sheet metal type that are center bolt. Since I could never get the passenger side flat, I converted the pass valve covers to use all eight screw downs. The side that does not leak is the drivers side with only center hold downs.
The issue is the PVC/breather system. I have a healthy vacuum for the PCV, but I am unsure of the breather. I fab'd a line to the same port on the throttle body as stock config. Does a 427 ci need a different breather solution?
ZD1 is offline   Reply With Quote
Old 05-22-2009, 09:23 PM   #2
gkull
CF Senior Member
gkull's Avatar
The problem with older AFR heads is poor oil return and the outer edge lip is so low. You end up with oil above the gaskets. I hogged out the oil return holes and on a vertical mill I machined a 1.2 wide trench right down to the spring pocket surface.
I use the tall Dart cast covers with the silicone gasket with metal hole incerts. I have not had a leaking problem.
Glad to see another 427 sbc out there. I have a 434 motown small journal motor
gkull is offline   Reply With Quote
Reload this Page leaky valve cover afr or risque pcv breather?
Tags
427, afr, breather, c5, corvette, cover, covers, leak, oil, pcv, pvc, sbc, tech, tips, valve
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
