Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ Photo AlbumsGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-24-2009, 03:06 PM   #1
Dave64
CF Senior Member
1964 Chevrolet Corvette
Dave64's Avatar
Default Which Head Gasket?
You guys have helped me before, but I'm now at another crossroads. I'm rebuilding my 327 L76, but not to original CR. Have replaced the original 4-speed with a 5-speed TKO 600. Here are specs, so far:
0.040" overbore
Deck Height 9.005"
TRW Flat-tops (L2165F (pin height 1.671"), so pistons are 0.009" in the hole at TDC
Edelbrock Performer RPM Aluminum heads (64cc)
Crower Sportsman 5.7" rods
CompCams 30-30 Mechanical Flat Tappet
FelPro Head Gaskets 0.039" crush
I plan on using either Edelbrock AirGap or Performer RPM intake with either Holley or Edelbrock 650~750 cfm
Calculations show me at 9.6:1 cr. Is this cr going to work with this combination, or should I use thinner head gaskets and work toward a 10.3~5:1 cr? The car will be a cruiser with occassional hard runs.
Any recommendations on p/n's for head gaskets?
Thanks,
Dave
Dave64 is offline   Reply With Quote
Old 03-26-2009, 03:02 PM   #2
Bubs
CF Senior Member
1973 Chevrolet Corvette
Dave,
You will probably get more response up in the C2 or C3 tech areas.
Bubs is offline   Reply With Quote
Old 04-07-2009, 08:40 PM   #3
71coupe
CF Senior Member
71coupe's Avatar
I've have these on my current 355 w/aluminum heads:
Fel-Pro Performance Z1094
http://store.summitracing.com/partde...4&autoview=sku
No problems for the past 9 years & 50k miles. I did put a little sealant around the water holes tho. With these, my comp is around 9.75
71coupe is online now   Reply With Quote
Old 04-11-2009, 06:00 PM   #4
cardo0
CF Senior Member
cardo0's Avatar
Location: So Cal- - Defend your ideas with facts. Not personal attacks.
Default Cometic will make custom gaskets but how much thinner can u go?
U can go to 10.5 c.r. with alum heads and any cam, but can u find a good thinner gasket? More compression is only going to help and add power but the real question is are there good thin gaskets for alum heads? There are plenty of good thick gaskets out there on the self but not many thin heads gaskets for alum heads.
U got the quench nailed now but any gasket under 0.020" is in danger with your .009" deck.
I would try another route. Have u bought the heads yet? Can you exchange your heads if already paid for? Edlebrock makes a set of Performers to replace the L98 corvette heads that have tighter chambers = 60cc. These heads have runners that would better match your smaller 327 cubes too.
Not sure if this is what u wanted to hear but good luck with your vintage block overhaul.
cardo0
__________________
74 T-top, L-48, 4spd, A/C, narly blue. Goodwrench 350 underwent new heads (SR Torquers), cam (crane XXXXXXXX) and Thorley headers due to domino effect of broken motor mount >broken fan shroud>remove radiator & A/C package. Now runs a Performer Air Gap with a lars majic chokeless Qjet on top. Also Street dampner, MSD dist, 6AL and Baster II.
http://members.cardomain.com/cardo0
cardo0 is offline   Reply With Quote
Old 04-14-2009, 12:16 AM   #5
71coupe
CF Senior Member
71coupe's Avatar
Cardo, funny you should mention that. I chose those gaskets because Felpro said that the steel shim gaskets cause less brinnelling on aluminum heads than the regular type composite head gaskets.
Reload this Page Which Head Gasket?
Tags
2002, aluminum, brinnelling, c3, c5, corvette, felpro, gasket, gaskets, head, heads, performance, problems, z06, z1094
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
L98 Head gasket failure question. Plasticman C4 Tech/Performance 25 11-05-2003 11:32 PM
SuperRam Done! But guess what...head gasket blown? B84RADR C4 Tech/Performance 25 07-25-2003 04:58 PM
still low compression on #7 after doing head gasket... rwj383 C5 Tech 22 07-30-2002 07:19 AM
Blown Head Gasket!!!!! Warp70 C3 Tech/Performance 18 01-31-2002 12:37 PM
Advertise Here - Contact Us - Corvette Enthusiast Discussion Forum - Archive - Top
Powered by vBulletin
Search Engine Friendly URLs by vBSEO 3.3.2
