Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-11-2009, 11:51 AM   #1
Kensmith
CF Senior Member
Support Corvetteforum!
Kensmith's Avatar
Ken Smith
Default Hydraulic roller VS Hydraulic
What is the big advantage of running a Hydraulic roller cam over Hydraulic in a 383 stroker? I know the cost to set up the roller is about $500 more so what's the big benefit?
Kensmith is online now   Reply With Quote
Old 03-11-2009, 01:35 PM   #2
gkull
CF Senior Member
gkull's Avatar
The cost difference is more like $1000 - $2000 more for a roller setup.
Smooth higher Hp.
gkull is offline   Reply With Quote
Old 03-11-2009, 06:02 PM   #3
mr.beachcomber
CF Senior Member
mr.beachcomber's Avatar
The roller cam will allow a more aggressive lift profile and less cam lobe wear on a street engine. The cost difference is predominately due the nature of the roller cam (steel) vs. flat tappet cam (cast iron) plus the need for roller lifters. With the reduction of zinc (or ZDDP) in current non-racing motor oils, I for one would be reluctant to run any flat tappet cam on the street.
mr.beachcomber is offline   Reply With Quote
Old 03-25-2009, 09:01 AM   #4
rodj
CF Senior Member
rodj's Avatar
If you were interested in going roller cam and starting a rebuild from scratch you would use a factory roller block.
'96-'00 L31 Vortec truck block; 4 bolt mains w/ roller cam are common and cheap.
By doing so you can use factory roller lifters @ $110 a set v $450 for the link style lifters required for non roller blocks
Roller cams in either style run $100+ more than flat tappet oes.
rodj is offline   Reply With Quote
Old 04-20-2009, 01:04 AM   #5
DSR
CF Senior Member
Ken: I'm all for the newer technology. My last 3 street motors have been hydraulic roller cam motors with roller rockers & fluid dampers. All have been high torque, low rpm motors. Lots of fun to drive on the street. All that fun does cost $$. If I can recall correctly it was some think like $1500 Cdn. for the roller cam set up.
Dave Rainthorpe
DSR is offline   Reply With Quote
Old 07-17-2009, 02:55 PM   #6
grumpyvette
CF Senior Member
grumpyvette's Avatar
http://www.idavette.net/hib/camcon.htm
read thru this
grumpyvette is offline   Reply With Quote
Old 07-23-2009, 01:03 PM   #7
Cstraub69
CF Member
Roller lobes allow more area under the curve so if you take duration at .050" on a roller cam and say it is 212 the equivalent on a flat tapped would be in the 228 range. The lift rate that the flat tappt can climb the lobe is much less intense then a roller lobe with a roller tappet. In a nut shell you can get more cam lobe area with a roller.
Oils. The gov has got us backed against the wall after removing all the anti wear properties from oils. The big three don't produce auto's with flat tappets anymore so as far as the Gov is concerned the additivies don't need to be in the oil. With a flat tappet you are limited to Joe Gibbs or Brad Penn oils for flat tappet cams.
QC PPM. What cam cores and flat tappets that are produced are sold to the aftermarket. The aftermarket does not maintain an overall QC department for the industry nor are the mfg of these parts held to very low PPM failure percentages. So in a nut shell, these parts aren't what they use to be.
Cost. Yes a flat tappet cam is cheaper but if you loose the cam and lifters and have to take the engine apart for a flush then that $200 cam change can run $1000. I tell customer long term you are better off with a hyd roller and a set of Retro hyd rollers for a car that is going to get driven.
That my take as a mfg in this industry.
Cstraub69 is offline   Reply With Quote
Reload this Page Hydraulic roller VS Hydraulic
Tags
advantages, cam, fla, flat, hyd, hydraulic, motor, roller, tappet, versus
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Hydraulic vs Mechanical Roller Dougs 90 Engine Mods 30 09-27-2005 11:04 AM
Hydraulic Roller vs Solid Roller... Kwik88 C4 Tech/Performance 13 01-04-2005 12:24 PM
Solid Roller cam vs. Hydraulic Flat Tappet RLH C3 Tech/Performance 9 08-18-2004 12:08 AM
Mechanical vs. Hydraulic, Roller vs. Flat OatBoy Engine Mods 9 06-25-2003 02:05 AM
solid lifters Vs hydrolic British Mark C3 Tech/Performance 11 02-26-2002 06:27 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
