How much power can a standard 350 block handle?
Old 01-26-2002, 12:42 PM
Lohkay
Lohkay's Avatar
Default Re: How much power can a standard 350 block handle? (tntcorvette)
for 1000+ I'd suggest a dart block like montey's....its pretty much the only block solid enough. I guess the motown block could be a close 2nd.
Old 01-26-2002, 01:58 PM
mackeyred96
mackeyred96's Avatar
Location: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Im looking for something that can handle 1000 + hp
Is that rearwheel or flywheel????????? :lol: :lol: :lol: :lol: :lol:
Old 01-26-2002, 02:37 PM
Monty
Monty's Avatar
I'm sure people have done it with a production block, but I don't think it would be the best way to go. A bowtie block might be a good option, they aren't rated for it from GM, but neither is the Rocket block - and that's what Meaney is using. You can usually pick up a bowtie (non-cnc) for around $650. They come with splayed steel 4-bolt mains. You could also call around to the various used racing parts places and see if they have any used Dart or Rocket blocks. Typically they'll just need to be cleaned up and overbored to the next sie, but you can get them for a good deal.
Old 01-27-2002, 12:06 AM
snaketr
snaketr's Avatar
That would depend on your setup. I know I've seen your posts in the TT threads, and if you are making this power with turbos then your answer would be yes, but you would need a 0010 2 bolt block converted to splayed 4 bolt setup. Second your tuning would have to be on the money, Gen VII or SpeedPro unit. If you had and pre detenation that block would be history. I would go with a little M by Dart or a Motown block.
Old 01-27-2002, 12:12 AM
74vetteman
74vetteman's Avatar
Default Re: How much power can a standard 350 block handle? (snaketr)
Using a stock Chevy block and all stock internals, David Vizard made 1027 hp and 950 ft/lbs. before cracking the block in the lifter valley! Of course he was using lots of spray> :crazy:
Old 01-27-2002, 11:50 AM
korvetkeith
korvetkeith's Avatar
Default Re: How much power can a standard 350 block handle? (74vetteman)
You can get your block cryoed in decatur, a complete motor is like 600, I'm not sure if a short block or just a block would be cheaper. It might not be worth it if you can get something aftermarket for what you spent getting it cryoed.
Hey Monty, do they make bowtie's with 4.100"+ bores for 650?
To How much power can a standard 350 block handle?
Quick Reply: How much power can a standard 350 block handle?
