Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-03-2009, 06:14 PM   #1
Belgian1979vette
CF Senior Member
Belgian1979vette's Avatar
Default would it be possible
To use an automatic trans coupled to the engine and with the output shaft connected to a torque arm, to work as an engine brake ? I would like to experiment building a home build dyno that way to lug the motor in order to do some tuning on my efi system.
Belgian1979vette is offline   Reply With Quote
Old 03-13-2009, 01:06 AM   #2
gkull
CF Senior Member
gkull's Avatar
Yes you could put a load the same thing as power braking a motor at the starting line.
my engine dyno at work is basically a water pump that measures the bending force applied to the pump housing
gkull is online now   Reply With Quote
Reload this Page would it be possible
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
C4 Custom Wheels...if you could design an affordable wheel what would it be? NitrousSam C4 General Discussion 12 05-06-2004 03:59 PM
how difficult and pricey would it be to build a new C3 using aftermarket parts? Chinaski C3 Tech/Performance 14 03-09-2003 04:15 PM
Would it be possible to hide the antenna internally? Sting Raycin C3 Tech/Performance 13 12-19-2001 12:10 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
