Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 03-02-2009, 07:05 AM   #1
rahaul
CF Senior Member
Default Premature roller cam failure BB LS6
Have been very pleased with this cam/ valvetrain that was recogmended by a local engine builder / friend of mine. Herbert cams are well known to be fine products. After some "not quite right" sounds from the left bank, I tore it down hoping to find a lifter in need of replacement. Cam and rollers look like corn cobs. Herbert tech says sounds like excessive spring pressure. Send it to us. I also am hearing about roller needle bearing failure issues and some manufactures have gone to a heavier built needle bearing. I built this BB 12 yr ago fully expecting 100K miles, not 60K. The failure is definately not from exessive RPMs. The 65 is a cruise car and only sees the redline on occasion to clear the exhaust. Any help appreciated.
rahaul is offline   Reply With Quote
Old 03-02-2009, 01:09 PM   #2
PuddleJumper
CF Senior Member
PuddleJumper's Avatar
that sucks. let us know how it turns out
PuddleJumper is offline   Reply With Quote
Old 03-03-2009, 11:57 PM   #3
Ironcross
CF Senior Member
Ironcross's Avatar
Default If it was Mine
Racing camshafts do not last very long without frequent attention. 60K miles is more than a lifetime for roller camshafts. Spring pressure is a requirement and also a rev-kit is mandatory to keep those heavy lifters from bouncing off the cam. Take the thing out and put a good flat tappet cam as a L72 or L71 cam and they give trouble free performance. Remember those two engines came with the 50K or 5 year warranty. And as a side lite, use the stock rockers if your not using them now.
Ironcross is online now   Reply With Quote
Old 03-05-2009, 01:06 AM   #4
gkull
CF Senior Member
gkull's Avatar
Solid rollers need oil. So low rpm and oil pressure is harder on them. The rollers need inspection periodically.
gkull is offline   Reply With Quote
Old 03-05-2009, 07:17 AM   #5
rahaul
CF Senior Member
Quote:
These are hydraulic rollers. We may indeed have an oilling issue since the damage is 90% on the left bank.
Reload this Page Premature roller cam failure BB LS6
Tags
c3, cam, camshaft, corvette, engine, failure, lifter, ls6, racing, redline, roller, springs
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
