03-03-2009, 07:24 PM
CF Senior Member
yup if you have the cats with the Gen III and IV Small block you make an ton more power. its because they were designed to be run with cats.
the computer reads the sensors before and after the cats to make precise fuel air mixture, the computer uses "knock senors" to ajust timing or even shut of the cylinder or the whole engine if its really bad to keep the engine from knocking from poor fuel.
now the Gen I small block runs better with out cats, but im shure if you put the cat from an C6 corvette in place of an C3s cat i bet you would see an increase of performance because the new cats work better and flow better to. the exhaust manifolds are made to keep the Exhaust Gass Temp hotter to make the cat work better.
Ryan
