Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-19-2002, 11:21 PM   #1
Beach Bum
CF Senior Member
Beach Bum's Avatar
Default "The Dude's Results ? "
Alright Jack, as you obviously know I couldn't make it out.... so how'd it go !!! Give it up, we want results !!! Did you run on the street tires or slicks ?
Beach
Beach Bum is offline   Reply With Quote
Old 01-20-2002, 03:16 AM   #2
The Dude
CF Senior Member
The Dude's Avatar
Default Re: "The Dude's Results ? " (Beach Bum)
Street tires. 3 passes only. Rolling gently into the throttle and still spinning 20-30 feet every time. :lol: Baseline setup: 32 deg. total timing, "all in" at 3,000. 91 octane pump gas. :U Shifting at 5,500. (Very conservative, yes?) No tuning, tweaking, adjusting, jetting or other forking around between runs. As you can see it is not quite up to its potential and the driver's rusty, too:
No. 1:
R/T = .930
60' = 2.139
330' = 5.731
1/8 ET = 8.646
1/8 MPH = 85.00
1/4 ET = 13.275
1/4 MPH = 105.37
No. 2:
R/T = .535
60' = 2.199
330' = 5.805
1/8 ET = 8.742
1/8 MPH = 84.18
1/4 ET = 13.395
1/4 MPH = 105.00
No. 3 (Found a wild off-idle bog on this one)
R/T = .919
60' = 2.246 (!)
330' = 5.896
1/8 ET = 8.853
1/8 MPH = 83.56
1/4 ET = 13.557
1/4 MPH = 103.42
I'm completely disregarding everything except 1/8 and 1/4 MPH. I like the way it picks up +/- 20 MPH during the second half. It felt a little down on power across the board, though. I have many things to think about over the next week or so and timing and fuel delivery are first as is putting on a few more miles to make sure everything is seated properly. Remember, this has about 100 miles on it now--most of it below 3,000 RPM and at idle.
It was fun. I had roach coach nachos. Mmmmmm. Cheesy.
The Dude is offline   Reply With Quote
Old 01-20-2002, 01:52 PM   #3
Beach Bum
CF Senior Member
Beach Bum's Avatar
Default Re: "The Dude's Results ? " (The Dude)
For your motor break-in, thats not bad.... but obviously a ton of et left through tuning and stickies. You going out next Saturday ? I'm definitely headed out next Saturday.
Beach
Old 01-21-2002, 12:15 AM   #4
LPDesRoche
CF Senior Member
LPDesRoche's Avatar
Send a message via AIM to LPDesRoche
Not bad for some shake down runs. With a little tuning and practice it will be right where you want it. :cool: :cheers: :cool:
LPDesRoche is offline   Reply With Quote
Old 01-21-2002, 05:54 PM   #5
The Dude
CF Senior Member
The Dude's Avatar
Yup, I'm there Saturday. Better tuneup. I'm also removing the PCV valve. I made a mistake and plumbed it directly to the manifold runners. This created a wicked vacuum leak AND contributed to the mixture in cylinders No. 2 & 4 being grunged up with blowby scuzz. I expect the elimination of this situation will contribute to a little better power output.
Old 01-22-2002, 01:03 AM   #6
Beach Bum
CF Senior Member
Beach Bum's Avatar
See you their.
Reload this Page "The Dude's Results ? "
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
WCCC Results from Event #2, 2/28/04...Winner is Dave Dowdell Blue85L98 Drag Racing 18 03-08-2004 02:44 PM
Fiberglass guru's...What to use when cutting my hood??? 1Bad69 C3 Tech/Performance 33 02-12-2004 09:26 PM
My 6-hour car care day... The Dude Car Care Discussion 9 08-27-2003 02:21 AM
Cerra Upgraded Turbo Final Tune Results Earl H C5 Forced Induction/Nitrous 22 07-02-2003 08:58 PM
Results form ATCO Raceway tonight. C5_PIG C5 Tech 42 03-07-2002 06:08 PM
The Crank Is In! bence13_33 C3 Tech/Performance 29 02-21-2002 02:39 AM
Does the Powerloader "lock out" PCM reprogramming from other tuners? smosier C5 Tech 39 09-13-2001 12:07 AM
Ennis Track Results......... CMilVette C5 Tech 15 08-21-2001 07:19 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
