01-20-2002, 12:59 AM
CF Senior Member
Re: Solid roller valve train ? (88-406)
I don't know about the longevity of parts, although I'll be finding out
because I'm building an engine with a solid roller.
The biggest advantage to the solid roller vs. hyd. is that the opening
ramps can be "steeper". There are limitations to the hydraulic due to
keeping the plunger from collapsing (there is a technical term for this
but it escapes me), which is compounded by the fact that the hyd. lifter
is heavier (therefore more mass to move).
Anyway, I'm curious too about the life of valve guides, etc with strong
springs and occasional high rpm use - we'll see!
Dan
