Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-19-2002, 05:49 PM   #1
dtorc4
CF Senior Member
dtorc4's Avatar
Default Question about 400 sbc
Is this the only motor that used an 8" harmonic balancer from the factory? If it is, I found one in a junkyard. I couldn't tell if it had steam holes b/c the heads were still on it. Even if the heads were pulled, I wouldn't know where the steam holes are. Thanks. :cheers: :cheers:
dtorc4 is offline   Reply With Quote
Old 01-19-2002, 06:39 PM   #2
American Boy
CF Senior Member
American Boy's Avatar
Default Re: Question about 400 sbc (dtorc4)
Find the block identification number. It's located at the rear of the block at the driver side. Usually cover with crud. Then you'll know for sure by posting this number here.
Stephan
American Boy is offline   Reply With Quote
Old 01-19-2002, 09:06 PM   #3
CFI-EFI
CF Senior Member
CFI-EFI's Avatar
The casting number, as stated above, may be the best way. Other clues: The balancer should be "unbalanced". Feel around to the inside. If it isn't a constant ID on the back side, it's "unbalanced". Check the flywheel/flex plate for an "unbalance" weight. 400's are externally balanced and the balancer and flywheel/flex plate have the "unbalance" weights. If it has 3 freeze plugs per side, it's a 400. Two freeze plugs don't say that it isn't a 400, but 3 say that it is. With a head off, rather than look for steam holes that you say you might not recognize, just measure the bore. The 400 is the only Chevy production small block with a 4.125" bore. The stroke is unique, too, at 3.75". Good luck. I hope you've found yourself a "jewel".
CFI-EFI is offline   Reply With Quote
Old 01-20-2002, 01:36 AM   #4
dtorc4
CF Senior Member
dtorc4's Avatar
:cool: guys, I am going to go check it out again tomorrow. I might have a problem getting the block ID b/c the engine is still in the truck. It is currently in a 75 (or 76? - 05/75) "Custom Deluxe 10". The VIN is CCQ145F390602. It has a total weight of 5300 lbs, w/ 2940 front/2940 rear (I guess GM doesn't know math :jester:)
Old 01-20-2002, 02:46 PM   #5
dtorc4
CF Senior Member
dtorc4's Avatar
I think I have the casting number. The numbers might be different from what I wrote down b/c it was really hard to see them. Try this:
4601028
1601028
4601020
1601020
etc, etc, etc
The 1s could be 2s or 7s, the 8s could be 0s, 0s could be 8s. HELP!!! :confused: :confused: :confused:
Old 01-20-2002, 04:50 PM   #6
LPDesRoche
CF Senior Member
LPDesRoche's Avatar
Send a message via AIM to LPDesRoche
Did you look for the freeeze plugs????
LPDesRoche is online now   Reply With Quote
Old 01-20-2002, 06:41 PM   #7
clem zahrobsky
CF Senior Member
Cruise-In I Veteran
Cruise-In II Veteran
clem zahrobsky's Avatar
casting # 3951509,3951511, the 511 could be a 2 bolt. if you are going to make power you had better install angle bolt main caps to hold the bottom end together :chevy
clem zahrobsky is offline   Reply With Quote
Old 01-20-2002, 10:44 PM   #8
corvgreg
CF Senior Member
corvgreg's Avatar
Default Re: Question about 400 sbc (clem zahrobsky)
The 2 bolt main 400 blocks are stronger than the 4 bolt. No need to upgrade the main caps unless you're way up in power/RPM.
corvgreg is offline   Reply With Quote
Old 01-20-2002, 11:48 PM   #9
dtorc4
CF Senior Member
dtorc4's Avatar
Default Re: Question about 400 sbc (LPDesRoche)
It had 2 freeze plugs on either side. Another thing I saw was that "A-207" was cast into each side of the block next to the rear freeze plugs. Is this anything?
Old 01-21-2002, 02:24 PM   #10
dtorc4
CF Senior Member
dtorc4's Avatar
:cry :cry :cry It's not a 400 :cry :cry :cry
http://www.geocities.com/MotorCity/5654/cblkcast.html
I checked my numbers against this page and there is no way that the 400 #s even come close to what I could decipher. :cry
Old 01-21-2002, 04:25 PM   #11
want2drivemy85
CF Senior Member
Send a message via Yahoo to want2drivemy85
You might want to ask "the dude' , the reason being I posted a question similar to this one before(check archives) and it was mentioned that a 400 with the 509 or 511 casting numbers were excellent blocks due to the extra iron, nickel content. Also my 400 only has 2 freeze plugs, but it has a boss for a third.
want2drivemy85 is offline   Reply With Quote
Old 01-21-2002, 04:48 PM   #12
snaketr
CF Senior Member
snaketr's Avatar
Default Re: Question about 400 sbc (want2drivemy85)
The easiest way to check. Fell the bottom of the block, if you can see the cylinder raised in the side of the block it is a 400. The 350 were flat all the way across.
snaketr is offline   Reply With Quote
Old 01-21-2002, 06:08 PM   #13
The Dude
CF Senior Member
The Dude's Avatar
Check out the SBC block casting nubers on http://www.moretec.com. to see what casting Nos. were 400s for sure.
Sometimes it's tricky to tell when you're not sure. Some 400s have 3 freeze plugs. Some have 3 freeze plugs and a center boss. Other have only 2 freeze plugs.
No, 400s aren't the only ones that used an 8" damper from the factory but it's the only SBC with the counterweighted, "scalloped" damper. Turn the engine over by hand until you see the timing mark. If the rear edge of the damper on the half of the balancer that contains the timing mark looks "cut down" it's a 400 damper. At this point you have a 400. Or a 383. Or a 350 that shook like a dog crapping razor blades when it was running.
And, as previously mentioned, all 400s will have at least one rounded contours on the outside of the block that correspond with the cylinders.
The steam holes are another tell you can use if the heads and balancer are off. Look between the cylinders. Between each cylinder you'll see two small holes that aren't there on other SBCs. I believe they're about 1/8" diameter or so. There should be corresponding holes between the combustion chambers in the heads if they are correct. Without those steam holes in the head and the proper head gasket the 400s will overheat. (And there is the genesis of the old wive's tale about how prone to overheating 400s are.)
Other 400 things:
--2-bolt blocks are stronger than 4-bolt blocks.
--'509 or '511 castings are, I hear, the "best" because they have the best chance of being high nickle/tin alloy blocks. Whatever. Probably means nothing except to a machinist.
--Virgin, unbored 400 blocks are getting harder and harder to find. You should make it your business to buy them whenever and wherever you find them. Or at least one spare to have on hand.
--Find them in full-size sedans--Caprice, Impala, etc.--station wagons and some trucks and vans.
Have fun. Post a block casting number when you get it. It will be on the rear driver's side of the block and it will be large, embossed numbers.
The Dude is offline   Reply With Quote
Old 01-21-2002, 07:36 PM   #14
CFI-EFI
CF Senior Member
CFI-EFI's Avatar
I pulled out the service manual for my '78 GMC pick up, to see if I could decipher your VIN. Just about everything coincides EXCEPT the engine code. The third character (Q) indicates the engine. "Q" was not used in '78. My '78 400 has an "R". If you can find someone with a '75 book, the clue is in the "Q". I may be wrong, but I'm not sure the 400 was availible in the half ton.
Old 01-22-2002, 03:56 PM   #15
corvgreg
CF Senior Member
corvgreg's Avatar
Default Re: Question about 400 sbc (CFI-EFI)
The high tin and nickel blocks will have "010" and "020" indicated in the timing chain area.
Old 01-22-2002, 09:25 PM   #16
The Dude
CF Senior Member
The Dude's Avatar
Default Re: Question about 400 sbc (corvgreg)
Well, Greg, long time no see. You have the copper/gold monster back on the road?
Reload this Page Question about 400 sbc
Tags
400, 400s, 400sbc, balancer, block, chevy, harmonic, hinickel, hinickle, identifaction, identification, no, numbers, sbc, to511ctl
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Stroking a 509 casting 400 SBC? LD85 Engine Mods 15 11-21-2003 08:35 AM
What new 400 SBC blocks are avalible? garagedweller2 C3 Tech/Performance 12 01-13-2003 08:32 PM
HIGH PERFORMANCE 2-bolt SBC - 4 bolt just for bragging? MARKUS_P C3 Tech/Performance 24 12-06-2002 05:15 PM
Question 1: Big block vs Small block Atomic Fusion C3 Tech/Performance 55 11-07-2002 06:14 PM
SBC Crankcase Ventilation – SWC Duke Muttley C1 & C2 Corvettes 27 04-13-2002 12:22 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
