Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-18-2002, 12:13 PM   #1
Monty
CF Senior Member
Monty's Avatar
Default A killer supercharger motor on CamaroZ28.com being built...
Guy by the namme of Blownbird. Looks pretty sweet.
http://photos.yahoo.com/bc/badsbrd/v...c=ph%26.view=t
Monty is offline   Reply With Quote
Old 01-18-2002, 12:53 PM   #2
Lohkay
CF Senior Member
Lohkay's Avatar
Send a message via ICQ to Lohkay
Default Re: A killer supercharger motor on CamaroZ28.com being built... (Monty)
Very sweet indeed. Just love where the alternator ended up. :) Do you think thats a custom injection system? Never seen those kind of rails.
Lohkay is offline   Reply With Quote
Old 01-18-2002, 01:11 PM   #3
Monty
CF Senior Member
Monty's Avatar
Default Re: A killer supercharger motor on CamaroZ28.com being built... (Lohkay)
I beleive that the throttle body and elbow are from Accufab - the guys at Fast Times use them alot and it looks familiar. The manifold is either a Victor Junir or a Super Junior - I'm guessing Super Junior cause it looks bigger. I've seen those rails before, they aren't production, but I don't know who makes them. I'd guess Accufab as well since thats where the TB and elbow appear to be from.
The low mount alternator it a pretty good idea, and it sure does clean up the top of the motor, especially if you're trying to make room for a supercharger or turbo(s). It would solve a couple of my packageing issues, but I don't know if it would work on a Vette due to the crossmember. Those Camaro's have a removable K-member that alot of those guys modify or buy aftermarket to fit. I wonder if the low mount exposes the alternator to more road dirt and water - and if it would negativelt affect it's durability.
It looks like a very nice setup and should probably make alot of power.
Old 01-18-2002, 01:20 PM   #4
Lohkay
CF Senior Member
Lohkay's Avatar
And besides, isn't the engine further up front on a camaro? Leaving space for the pulleys and stuff? As for the intake, the super victor was my guess. Its a good thing to know that EFI can be fitted on that intake.
Old 01-18-2002, 01:43 PM   #5
Monty
CF Senior Member
Monty's Avatar
Jeez, I thought I was bad. I just read a post over on the Thirdgen.org site by Blown bird that he's selling the supercharger setup, and going turbo. He just installed the motor in the car recently, and hadn't even completed it. http://www.thirdgen.org/techbb2/show...threadid=77488
Power corrupts, judging by what I'm seeing on the various car forums, there's gonna be quite a few pump gas 1000+hp turbo street cars out there pretty soon.
Old 01-18-2002, 02:53 PM   #6
Lohkay
CF Senior Member
Lohkay's Avatar
Yeah, you guys have me all confused....how the hell can you hook up 1000+hp with street tires? Even on a track, you'd be spinning up to your top gear. You did try your 675hp engine right? I'm sure you already had some major traction problems no? Just asking as I'm planning a 800hp BB for the near futur but if you all think it ain't enough, there must be a reason. :crazy:
Old 01-18-2002, 03:38 PM   #7
Monty
CF Senior Member
Monty's Avatar
I have to keep street tires because I'm still running the stock, but beefed up, Corvette IRS. I've had thoughts about going to a 4-link 9" or Dana60, but since my car is 95% street, I'd prefer to keep the IRS as long as I can. think switching back to an automatic transmission will help some, since they aren't so hard on the driveline - assuming I keep the 4L80E shift firmness programming reasonable.
I ran the naturally aspirated 650hp SBc 427 for about 5 weeks, and it was a handful but once you got the car pointed in the right direction and moving forward it was a blast. It's mainly just a matter of using some common sense, feathering the throttle off the line, and knowing how much throttle you can use in the corners. One advantage to the Corvette is that since the differential hard mounted to the frame, you don't have it moving around like a straight axle car.
I really don't think the twin turbo SBC 427 will be that much worse. I may even loose a little off-idle torque since my CR is lower, but it will more than make up for it after 3000 rpm, which by then the car will already be moving forward and hopefully won't have as much wheel spin and less shock to the drivetrain.
As for the reason - "power corrupts". My wife and friends always tell me they think I would rather be building the car than driving it, they may be right. But the bar keeps getting higher and higher, I just felt that the turbos were the way to go. I'm betting that after a few months or so, you'll get comfortable with your new BB and you'll start tinkering with it again. I guess I get bored with it once the fear of it wears off.
Old 01-18-2002, 04:00 PM   #8
Lohkay
CF Senior Member
Lohkay's Avatar
Thats what I thought....everytime someone says I'm nuts, I answer that you get used to the power you have rather quickly and after a long time you get bored of it and just want more. Even tough I thought there would be a limit somewhere when its just enough. I guess its higher than I thought. ;)
Old 01-18-2002, 07:21 PM   #9
LPDesRoche
CF Senior Member
LPDesRoche's Avatar
Send a message via AIM to LPDesRoche
That was a pretty sweet looking setup. The turbos should be just as nice. We shall see.... :cool:
LPDesRoche is offline   Reply With Quote
Old 01-18-2002, 08:02 PM   #10
Flareside
CF Senior Member
Flareside's Avatar
Yep, totally agree! I started out to build a 500 HP big block, and now I'm waiting for AFR to finish my new BBC heads that *they say* will make 750 HP with my setup if I can get a decent exhaust installed. :eek: :eek:
The problem, for me, seems to be that I just can't bring myself to buy lower power parts when the pricing is similar.
Flareside is offline   Reply With Quote
Old 01-18-2002, 08:31 PM   #11
69 N.O.X. RATT
CF Senior Member
69 N.O.X. RATT's Avatar
Location: Pettis Performance 565 with two stages of Nitrous Supply nitrous 1.082, 4.61 at 155, 7.17 at 192
Default Re: A killer supercharger motor on CamaroZ28.com being built... (Flareside)
Monty: Tried to find a low mount alternator set up for my big block, couldn't do it cross member was in the way. Could probably be fabbed up.
69 N.O.X. RATT is offline   Reply With Quote
Old 01-18-2002, 10:45 PM   #12
Merlin522
CF Senior Member
Merlin522's Avatar
Default Re: A killer supercharger motor on CamaroZ28.com being built... (69 N.O.X. RATT)
I like it. Nice clean setup & unique. Monty, stay with IRS. Once you cross the line, it's not a Vette!! :o)
Merlin522 is offline   Reply With Quote
Old 01-19-2002, 01:32 AM   #13
GlockLT4
CF Senior Member
GlockLT4's Avatar
Send a message via AIM to GlockLT4
:cool:
GlockLT4 is offline   Reply With Quote
Old 01-19-2002, 11:12 PM   #14
C3 Shark Tank
CF Senior Member
Try these guys, get the catalog because the web site isn't all that great, the catalog will have you drooling for hours though! http://www.hotrodlane.cc/ the place is called Street & Performance, they have tons of different setups for all kinds of applications, might be worth looking into. I'm ordering all the billet brakets soon.
[Modified by C3 Shark Tank, 9:14 PM 1/19/2002]
C3 Shark Tank is offline   Reply With Quote
Old 01-22-2002, 12:40 PM   #15
norvalwilhelm
CF Senior Member
norvalwilhelm's Avatar
You do reach a point where more power on street tires is useless. I have 940 destop dyno horsepower and with 305-50-15 TA radials in 3rd gear you still can not get on it fully. Last year I got a little to agressive and it went around taking 3 lanes of traffic. Luckily I didn't hit anything but it left me with new respect for power. After 35 years of hot rodding I finally have a motor that has more power then I can use on the street. It is smooth power from idle on up but I find myself bouncing off the rev limiter at 7000 in anything but 4th and 5th. My 843 HP nitrous motor with 4oo, 4.11 gears and slicks was alot
faster and easier to control.
norvalwilhelm is offline   Reply With Quote
Old 01-22-2002, 12:50 PM   #16
Lohkay
CF Senior Member
Lohkay's Avatar
Default Re: A killer supercharger motor on CamaroZ28.com being built... (norvalwilhelm)
Thats good to know norval....didn't know that you had 940hp....what do you have under that hood exactly?
Old 01-22-2002, 01:00 PM   #17
norvalwilhelm
CF Senior Member
460 cubic inches, 12 lbs of boost from a 8-71, super high flowing heads heavily ported, freeflowing exhaust, full roller valve train, 2 850 double pumpers, good ignition and 35 years of experience on how to get it all to work. In a nut shell that is all.
Old 02-03-2002, 01:32 PM   #18
Nat04Z06
CF Senior Member
Nat04Z06's Avatar
Oh man that's gotta be a wild ride! :eek: I can't iamgine what that kind of power feels like.
Nat04Z06 is offline   Reply With Quote
Old 02-03-2002, 07:15 PM   #19
GlockLT4
CF Senior Member
GlockLT4's Avatar
:cool: :cool:
Reload this Page A killer supercharger motor on CamaroZ28.com being built...
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
