I goofed up needs some advice on cam
Old 12-30-2008, 01:14 AM
MikeNKalibs6t7Coupe
MikeNKalibs6t7Coupe's Avatar
Default I goofed up needs some advice on cam
I pulled a bonehead stunt, tore my engine that I just bought down and was really getting some stuff done, so I thought got in a hurry and flipped the motor over on the stand to pull the pan, and heard thunk thunk was like what the heck forgot to pull the lifters now I have a used cam and I have a pile of lifters that I have no idea which lifter bore they came out of. Any advice on putting them back in with minimal risk of flattening the cam ? Or should I just pitch it ? I really do want to reuse it as its a solid lift crane from way back and really ran and sounded mean. thanks for any help in advance and yes I know haste makes waste
Old 12-31-2008, 10:57 PM
Curveit
Curveit's Avatar
I think it's time for a new set of Lifters. The Cam should ok.
Old 01-01-2009, 11:04 AM
gkull
gkull's Avatar
Received 1,327 Likes on 1,057 Posts
IMO - I never kept track of which lifter bore I pulled my Crane hi-int lifters.
It might make a difference on some old high mile junk motor. Just think about it. The lifter is rotating. it is polished smooth.
Old 01-02-2009, 10:06 PM
MikeNKalibs6t7Coupe
Default goof
thanks for the input guys did keep the cam for another car but I went and bought another comp cams 305 h magnum cam as the car is man brakes and vaccum is of no concern. I have run this particular cam before and really liked the performance cya at the track mike
To I goofed up needs some advice on cam
Quick Reply: I goofed up needs some advice on cam
