Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-18-2002, 02:23 AM   #1
JackCooper
CF Member
Send a message via AIM to JackCooper
Default cylinder heads HELP!
The heads on my 79 vette are cracked, so I figure since I've been wanting
to build my engine, I might as well start now.
The local mechanic told me to buy a set of 882 heads through him for 350 bucks.
He claims that with flattops and a decent camshaft, they will make my motor put out 300 rear wheel hp.
However, the tech books say that these heads are 76cc and are prone to cracking.
I was also looking at the 750 dollar a pair (complete) sportsman II heads. (BTW, will angle plug heads work in a c3 vette with headers, or will they interfere, and does anybody know if the sportsmans have accesory holes?)
I'm not sure which way to go. And I'm wondering if there is a middle of the road between those two options.
JackCooper is offline   Reply With Quote
Old 01-18-2002, 11:43 AM   #2
Lohkay
CF Senior Member
Lohkay's Avatar
Send a message via ICQ to Lohkay
Default Re: cylinder heads HELP! (JackCooper)
You can go with the 492 heads like the ones I have. They have accessory holes, 2.02/1.60 valves, 64cc chamber, 160cc intake (close to that). They have angled plugs and they work well with headers. But if you have the money for aftermarket heads, buy them. They flow much better than GM heads.
Lohkay is offline   Reply With Quote
Old 01-18-2002, 03:46 PM   #3
nunus79
CF Senior Member
The Sportsman IIs have all of the accesory holes. Everything bolted up perfectly. They are a good streetable upgrade. As for a "middle of the road" World Products puts out a Stock Replacement (SR) line of heads that many here use with good results. They have good (better) combustion characteristic than stock heads. The SR "Torquers" has the 202 160 valve size and make for a good upgrade also. The price is reasonable. Check out their web page for more info.
nunus79 is offline   Reply With Quote
Old 01-18-2002, 07:27 PM   #4
LPDesRoche
CF Senior Member
LPDesRoche's Avatar
Send a message via AIM to LPDesRoche
Default Re: cylinder heads HELP! (nunus79)
Definitely go aftermarket if you can. You will regret it later. Most aftermarket designs are far superior to stock castings. You may even want to go aluminum and bump the CR a bit.
LPDesRoche is offline   Reply With Quote
Old 01-18-2002, 08:55 PM   #5
The Dude
CF Senior Member
The Dude's Avatar
I must concur with everyone. Don't throw any money at old GM heads except as an absolute last resort. (Unless you go with Vortecs or something.)
The aftermarket has come a long way with cylinder heads and you can score yourself a brand-new set of S/Rs or similar for sometimes less money than you'd spend assembling and machining the stock stuff. Brand spanking new and they flow better, too--just bolt them on and go, daddy. You gotta love that.
The Dude is offline   Reply With Quote
Reload this Page cylinder heads HELP!
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
What cylinder heads do I have?? Victor C3 Tech/Performance 10 08-26-2005 01:35 PM
AFR New "LS" Cylinder heads..... Tony M C5 Tech 131 12-23-2003 02:02 PM
BB Cylinder Heads blunsford C3 Tech/Performance 11 09-12-2003 05:57 PM
what type of cylinder heads are you L48 guys using? sharkthehunter77 C3 Tech/Performance 29 12-13-2002 08:48 PM
Special Pricing on Agostino Racing Cylinder Heads and Cam Packages! MattG C5 Tech 19 11-20-2002 07:41 PM
BB cylinder head help J. Swisher C3 Tech/Performance 15 09-11-2002 09:30 PM
Cylinder heads and intake manifold VetticusSupersonicus C3 Tech/Performance 29 09-05-2002 12:12 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
