Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-17-2002, 05:56 PM   #1
NOS6SPEED
CF Senior Member
NOS6SPEED's Avatar
Default Engine Builder????
I'm going to have my engine rebuilt. I think it will be a 383, maybe more. Does anyone know an engine builder with a good reputation within a couple hours of the Fayetteville Arkansas area. I'd prefer to just drop the car off, but if necessary I can have the engine pulled and drop off the engine. Also what advice would those of you that have gone through this already give me. Should I go 396, 400 small block, 355 or what? I run a small shot of nitrous (50hp) right now but I'll build it for either a bigger shot or a supercharger. The car is not a daily driver, but I want to be able to drive it on the street. Would a solid roller setup be worth it, I'd like to do this once and be satisfied with the power. What kind of numbers would I be able to expect. The car has a More Performance top end kit now. I hope to be able to tell a significant difference. Thanks in advance for the help.
Josh
NOS6SPEED is offline   Reply With Quote
Old 01-18-2002, 12:05 AM   #2
drive it
CF Senior Member
Default Re: Engine Builder???? (NOS6SPEED)
I have to suggest-go with the cube inches! Get the 400-bored over it's a 406. Find a good 400 block (no core shift/cracks) and put on splayed 4 bolt billet main caps, a forged crank and the bottom will hold together for about anything. For high lift a roller is a must-don't know about solid though. Why not build it yourself?! Just find a reputable machine shop and bolt it together on an engine stand. I've done it; ain't that hard and it's an excuse to buy more tools!!! Then you can say it's "home built-more power-argh argh argh!" :cheers:
drive it is offline   Reply With Quote
Old 01-19-2002, 04:31 AM   #3
ol,RJ
CF Senior Member
ol,RJ's Avatar
solid rollers do need adjustment every 5000miles (approx), if thats not for you then go with a hyd roller.
if your going solid roller then build the motor for it ( ie; forged pistons ect )
you can use restictors in the lifter galleys then too (solid cams don't need as much oil volume). so make sure to tell the shop doing the work what your going to be running cam wise.
is it worth it? well maybe not, they do make some pretty aggressive hyd cams nowadays but if you want to rev the engine over 6000rpm on a regular basis then solid is safest.
ol,RJ is offline   Reply With Quote
Old 01-21-2002, 07:23 PM   #4
NOS6SPEED
CF Senior Member
NOS6SPEED's Avatar
Default Re: Engine Builder???? (ol,RJ)
Thanks. I'm thinking a solid roller 396 at this point. I'd love to go bigger, but I've been told the opti won't fit on a 400 and I'd have to scrap the ignition and computer system. That gets into a lot of money I'd guess.
Reload this Page Engine Builder????
Tags
builders, corvette, engine, tulsa
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Another engine builder goes bellyup MotorHead C3 Tech/Performance 36 03-23-2005 11:17 AM
Michigan Engine builder 95Purple Great Lakes 22 06-06-2003 06:17 PM
Engine builder pushing SBC over BBC??? ricketyray C3 Tech/Performance 27 03-08-2003 02:08 PM
my engine builder told me not to use the vaccume advance...why? yoslambo1@cs.com C4 Tech/Performance 9 06-27-2002 04:04 PM
I got an argument with engine builder about my LT1 stroker motor Bruce C4 Tech/Performance 17 04-28-2002 05:48 PM
My engine builder wants me to down compression to 9.5 whats up??? Dracula383 Engine Mods 10 10-24-2001 02:27 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
