Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-15-2002, 03:25 PM   #1
rainman69
CF Senior Member
rainman69's Avatar
Send a message via AIM to rainman69
Default 9" of vacuum???
I don't have a vacuum leak as far as I know, as I checked the vacuum at the manifold with all the accessories disconnected/plugged at the manifold. I know I'm at 6000', but shouldn't I still see around 12" idle...unless there's quite a cam in there.
Any ideas on what kind of cam? Power band is 2200+ and really is a rocket over 3000.
rainman69 is offline   Reply With Quote
Old 01-15-2002, 04:15 PM   #2
drive it
CF Senior Member
Default Re: 9" of vacuum??? (rainman69)
I just recently checked my vac.- I live at 7000ft.-at home 11in. and down the hill (about 1000ft) was 17in. Thats with cam specs of 222 and 228 at .050 on a 114 with .494 lift. So yup, altitude makes a big diff! And it sounds like your cam must be pretty "healthy". Oh yea-thats at an idle speed of 750rpm.
[Modified by drive it, 1:15 PM 1/15/2002]
drive it is offline   Reply With Quote
Old 01-15-2002, 04:55 PM   #3
Gordonm
CF Senior Member
Gordonm's Avatar
Default Re: 9" of vacuum??? (drive it)
That is about what I pull 9" in my car at about sea level. My cam has a 248 duration at .050. I idle at 800 to 850 rpm
Gordonm is offline   Reply With Quote
Old 01-15-2002, 05:22 PM   #4
gkull
CF Senior Member
gkull's Avatar
At your alt. You need to run more advance. At least 4 more than sea level. Then adjust your idle mixture screws with a vacuum gauge. When your dialing it in you have to keep lowering your idle speed.
gkull is offline   Reply With Quote
Old 01-15-2002, 05:33 PM   #5
RMS73
CF Senior Member
RMS73's Avatar
Check to see if you have vaccum in the crankcase: this would come from a leak on the underside of the intake manifold. Remove the dipstick and put the vac gage on the tube. My Vette was pulling 9.5" Hg on the intake and 8.5" Hg at the dipstick tube. Replace the intake manifold gaskets and intake vac went to 13.5"Hg and 0 at the cranckcase. Also the carburetor mix screws then had control over idle speed/quality.
Roger
RMS73 is offline   Reply With Quote
Old 01-15-2002, 07:51 PM   #6
rainman69
CF Senior Member
rainman69's Avatar
Will do crankcase check.
I am at 16 degrees initial, 37 degrees total.
Old 01-15-2002, 11:42 PM   #7
74vetteman
CF Senior Member
Check your vacuum gauge manual. My manual for my gauge mentioned for every 1000 ft of elevation you lose 1 inch of mercury. If your gauge is the same you would add 6 more inches at 6000 ft. I was having low readings as well and searched for vacuum leaks until I was blue in the face. :mad
74vetteman is offline   Reply With Quote
Old 01-16-2002, 01:30 PM   #8
rainman69
CF Senior Member
rainman69's Avatar
Default Re: 9" of vacuum??? (74vetteman)
Hmmm...ok. Next question along the same lines:
So, I did a compression check. All eight were at 90 +/- 2 psi. I'd say that was pretty consistent across the board, but a little low. I'm guessing that there's a good bit of overlap in my cam...is that a logical guess?
Old 01-16-2002, 04:02 PM   #9
mountainmotor
CF Senior Member
mountainmotor's Avatar
Post your cam card specs and I will be glad to tell you how much valve overlap you have :)
mountainmotor is offline   Reply With Quote
Old 01-17-2002, 01:20 AM   #10
rainman69
CF Senior Member
rainman69's Avatar
Default Re: 9" of vacuum??? (mountainmotor)
ummm....yeah... :jester if I had the cam card, I could tell myself the overlap. :lol: I was just hoping to get a ballpark figure, but from what I'm seeing here and what I'm simulating in DD2000, my current best guess is:
CompCams XE284H, 240/246 @ .050", .507/.510, Hydraulic (Valve overlap 23 degrees)
This results in a 383 Fly HP (SAE Net) at 6000, which makes sense. Also, helping to make sense is that while an examination down the pushrod hole shows a hydraulic lifter top, I have aftermarket dual valve springs. The heads had to be modified (by previous owner) to make them fit...
So...Maybe I'm on the right track. I just wish I knew if I still had the factory forged crank and forged domed pistons (11:1 comp ratio) or if it was bored out any... :smash:
Old 01-17-2002, 11:13 AM   #11
mountainmotor
CF Senior Member
The 23 degrees you posted is not actual overlap when running.I estimate 66-70 degrees of running overlap with that cam. :rolleyes:
Reload this Page 9" of vacuum???
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Vacuum advance question guycummins C1 & C2 Corvettes 28 04-21-2004 11:47 AM
List your cam and vacuum specs here. blunsford C3 Tech/Performance 17 11-20-2003 07:53 AM
how to calculate degrees of vacuum advance? Matt Gruber C1 & C2 Corvettes 9 09-11-2003 01:02 PM
Mine's 10 inches...of vacuum at idle. What's Yours? SAC C3 Tech/Performance 35 07-31-2003 09:11 PM
14" vacuum on rebuild at idle up to 20" @ 3000 rpm Ybnormal C3 Tech/Performance 13 09-20-2002 01:40 PM
Cutting out or bogging near top of RPM's - why? Captain Morgan C3 Tech/Performance 33 01-27-2002 11:59 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
