Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-15-2002, 02:32 PM   #1
GregP
CF Senior Member
GregP's Avatar
Default What size primaries (exhaust) ?
I'm starting to line up the stuff to fab the headers and side pipes. Since the block is in (and not much else) thought I'd do them while I have room to work around stuff. QUestion is how big of primaries to go with. Most Shoenfeld racing headers are using 1 5/8 dia. I can get collectors for 1-5/8, 1-3/4, and 1-7/8. I know 1 7/8 require either "squaring" the pipe or running double flanges to get the bolts to clear.
I'm "planning" to end up with something around 500HP and 396 cu in (small block). I run 2 1/8 primaries on the big blocks (460 cu in at ~475 HP), so am thinking I should go with the extra work and setup for the big 1 7/8 tubes.
What think you all or what size are you using for high HP mice?
-Greg
GregP is offline   Reply With Quote
Old 01-15-2002, 08:37 PM   #2
427Hotrod
CF Senior Member
427Hotrod's Avatar
Default Re: What size primaries (exhaust) ? (GregP)
If I was going to all the trouble to make headers, I'd use the 1 7/8". 500 hp isn't into the radical stage yet as far as HP but 396" is getting up there.
What RPM are you planning? If it's a big deal as far as clearance I don't think the 1 3/4"'s would kill you at that hp level. In fact, if you don't plan on upping Hp or spraying they might be the best choice. I just know me, and I ALWAYS end up looking for more HP. If you decide later to add a blower or whatever, it would be a shame to be choked up.
Jim
427Hotrod is offline   Reply With Quote
Old 01-15-2002, 09:06 PM   #3
gcrouse
CF Senior Member
gcrouse's Avatar
A good compromise might be 1-3/4"; the physical fit is easier though they are squared and you can still barely get allen head bolts in there. The size keeps exhaust velocity up for broader torque. I run Hooker SuperComp 1-3/4" on my supercharged 383 at similar power levels to yours.
But 1-7/8" is better if you want to shift the powerband upward- to reduce low-end torque induced wheelspin, and make max top-end horsepower. Since you're fabbing them you could do a nice tri-Y and get the primary lengths alot more even than off the shelf stuff.
Be sure your heads have big valves and great flowing exhaust ports though; or those giant headers are a waste.
gcrouse is offline   Reply With Quote
Reload this Page What size primaries (exhaust) ?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
what heat shielding to buy for clutch lines and o2 sensor wires? TT_Vert C5 Tech 14 05-20-2004 12:14 PM
C3 exhaust system help saudivette C3 Tech/Performance 13 05-04-2004 06:51 PM
Does anyone run angle plug heads with side exhaust? John Dirks C3 Tech/Performance 9 02-21-2004 05:12 AM
Help evaluate exhaust situation: Header swap from TTS to Kooks The One C5 Tech 10 12-19-2003 03:06 AM
3" exhaust is no better than a 2.5"... based on a test by VD Jeffvette C4 ZR-1 Discussion 20 09-21-2003 01:34 AM
What's the formula for finding a max flow (cfm) for a given diameter? TIMSPEED C4 Tech/Performance 32 05-14-2003 02:32 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
