01-17-2002, 05:40 PM
CF Senior Member
Re: Sprotsman II heads (68 Roadster)
Based on 1/4 mi mph results, the Sportsman IIs alone netted me a 55 horsepower gain over stock fresh rebuilt smog heads. They advertise a 30-70 bolt on gain.
The RPM manifold uses the same 1205 gasket size as recommended for the Sportsman II. So the intake ports should match-up real well.
Put in a decent sized cam and you are off to the races!!!!
PS Even if you are not going to play on the strip, this combo should be real streetable too.
[Modified by nunus79, 10:42 AM 1/17/2002]
