Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-15-2002, 01:33 AM   #1
GShyneDM
CF Senior Member
GShyneDM's Avatar
Send a message via AIM to GShyneDM
Default Nos and TURBO??
sorry..probably a dumb question.. but i am not much of a car modder...
i was just wondering if they can go together?
i thought turbos heat up your engines pretty good... and nitrous would add to it.. and be pretty dangerous...
i dunno.. PLease explain to me.. thanks :)
GShyneDM is offline   Reply With Quote
Old 01-15-2002, 06:03 AM   #2
KLLRVET
CF Senior Member
KLLRVET's Avatar
Default Re: Nos and TURBO?? (GShyneDM)
Actually, nitrous is an EXCELLENT intercooler. But, you must have a motor built to endure the stresses that come with the two.
Tony
KLLRVET is online now   Reply With Quote
Old 01-15-2002, 11:42 AM   #3
GShyneDM
CF Senior Member
GShyneDM's Avatar
Default Re: Nos and TURBO?? (KLLRVET)
Tony
AHHh... i see.. thanks :)
Old 01-16-2002, 06:10 AM   #4
GlockLT4
CF Senior Member
GlockLT4's Avatar
Send a message via AIM to GlockLT4
Tony
:yesnod: :yesnod: :yesnod:
GlockLT4 is offline   Reply With Quote
Old 01-16-2002, 07:50 PM   #5
LPDesRoche
CF Senior Member
LPDesRoche's Avatar
Send a message via AIM to LPDesRoche
Default Re: Nos and TURBO?? (Glock'94)
There are tons of Supra guys running a 100 shot on top of boost. Or Grand National guys for that matter. It works very well.
LPDesRoche is offline   Reply With Quote
Old 01-16-2002, 09:04 PM   #6
bill mcdonald
CF Senior Member
Default Re: Nos and TURBO?? (LPDesRoche)
Not only does it help cool the intake, it also helps spool the turbo and reduce lag.
Some of the supra guys run some pretty big turbos, with the 3L 6 it takes a bit longer to spool, so the N2O helps out a lot by creating more heat when it is burned... So all around it seems to work great. Just need a motor that can stand up to it.
bill mcdonald is offline   Reply With Quote
Old 01-17-2002, 12:33 PM   #7
C1 CMEGO
CF Senior Member
C1 CMEGO's Avatar
Default One helps the other
We used an early shot of NOS to help spool up the turbos with a pressure switvh to turn them off at 10 PSI it was a fine line on when to turn on & off as if you got it wrong all you saw was tire smoke it also cooled the charge air temps so the turbo could pack more density into the chambers I always wanted to try a starting with big shot & then tapering off progressivly but the electronics wernt up to it at that time
JJ
C1 CMEGO is offline   Reply With Quote
Reload this Page Nos and TURBO??
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
SGC TT ZR1 - BOOSTAMUV!! Rkreigh C4 ZR-1 Discussion 168 04-05-2004 01:50 AM
I bought a Twin Turbo supra this weekend ! 92LT1Roadster C4 General Discussion 79 10-25-2003 09:57 PM
Stock cube turbo LS1. Here is the potential we have. 700+ rwhp flynbludream C5 Forced Induction/Nitrous 32 08-18-2003 08:04 AM
Cast pistons and turbo charging shotgun_000 C3 Tech/Performance 11 04-21-2003 03:59 PM
L98 turbo, some questons jtjerry C4 Forced Induction/Nitrous 27 12-11-2002 12:22 AM
415 ZR-1 V's Turbo Supra LIMEY C4 ZR-1 Discussion 42 11-30-2002 12:50 AM
LPE TT c5 vs supra turbo dyno!! r1hooligan C5 Forced Induction/Nitrous 134 09-06-2002 08:10 PM
Halltech's TRIC Twin Turbo repaves the highway Halltech C5 Z06 Discussion 61 06-27-2002 05:51 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
