Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-14-2002, 04:33 PM   #1
MWILLET
CF Senior Member
Default Small Block Stroker Advice Needed
I'm considering stroking my current ZZ3 up to 383 cid this Spring, but I wanted a lot of advice before I get in too deep. My first consideration is whether the extra cubes will make it harder to pass emissions (it cuts it kinda close right now).
Second, what will I be able to reuse from the original long block (rods, crank, etc) and what will I end up buying. IIRC, the crank is one of Chevy's better pieces; do I have it reground or do I need a whole 'nuther crank?. Will I have to: get different rods? Smaller base circle cam?
What would you recommend for a cam (it currently has the ZZ3 hydraulic roller, and I'd like to stay with a hyd roller. Is this one too tame for a bigger street motor? (208/221@ .050 .494/.510) As I said, this is strictly a street motor, and I'm mainly concerned with lots of low and midrange torque.
Right now, the engine also has Twisted Wedge heads (circa '95), Hooker headers, high flow cat, Stage II Quadrajet backed by a B&M 2500 Holeshot & 3:07 gears.
Yes, I also posted this in the C3 section, but I'm looking for a broad spectrum of expertise.
Thanks for any advice
MWILLET is offline   Reply With Quote
Old 01-14-2002, 05:19 PM   #2
Lohkay
CF Senior Member
Lohkay's Avatar
Send a message via ICQ to Lohkay
Default Re: Small Block Stroker Advice Needed (MWILLET)
Well I never heard of the ZZ3 engine (only the ZZ4) but I figure its a 350? If so you need to get rid of that crank cause you need a 400. The rods need to be 5.7" I think and thats about all the parts you'll need. Someone else will most probably fill you in on this as this is a common mod.
Lohkay is offline   Reply With Quote
Old 01-15-2002, 01:06 AM   #3
korvetkeith
CF Senior Member
korvetkeith's Avatar
Send a message via AIM to korvetkeith
The ZZ3 is simply the predescessor(sp?) to the ZZ4, I can't remember how the bottom end is set up, but I believe it was mostly forged components, I remember the older ones have beefier parts. If your really set on low down torque the stroker is the way to go, the only reuseable part in the bottom end will be the rods. I think however it would be a shame to throw out the forged pistons and crank for a negligable power increase, if you gonna tear up that good bottom end atleast take it out to a 396. However the one thing your engine is setup well for, which is cheap, and will give you ungodly amounts of low end torque, is a big shot of nitrous. :yesnod:
[Modified by korvetkeith, 10:08 PM 1/14/2002]
korvetkeith is offline   Reply With Quote
Old 01-15-2002, 12:12 PM   #4
Cory@LS2PortWorks
CF Senior Member
St. Jude Donor '09
Default Re: Small Block Stroker Advice Needed (korvetkeith)
I went 12.89 at 110 on a ZZ4 stock bottom end. All you need is good ported heads, good exhaust, a good cam and a Super Ram to duplicate my results. I wouldn't recommend stroking unless you pick up some better aftermarket heads or get yours seriously ported out. You'll want the big valves 2.08 (int) and 1.6 (exh) minimum. You'll be disappointed otherwise.
Search the archives in this forum. Lots of good knowledge there. Also, we wouldn't have to repeat everything every week if people did a search.
Good Luck,
Cory
[Modified by CHarris85Vette, 7:15 AM 1/15/2002]
Cory@LS2PortWorks is offline   Reply With Quote
Old 01-16-2002, 01:25 AM   #5
korvetkeith
CF Senior Member
Default Re: Small Block Stroker Advice Needed (CHarris85Vette)
Cory
AMEN to that Cory :yesnod:
Reload this Page Small Block Stroker Advice Needed
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
what displacement does a 350 like most? CD Engine Mods 21 09-12-2003 12:23 PM
Doing research into 383 stroker..... Need advice. shamvette C4 Tech/Performance 11 06-23-2002 09:37 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
