Quote:
lol :( not a single yea... not lookin good
Jenny, you would not be happy with them in the long run. They do
look cool (ok, pretty). Aluminum rods are exotic as far as engine parts go.
I've built a number of engines over the years with aluminum rods (including
blown alcohol drag boats and a "qualifying only" engine for a road
racer). So I've had some hands on experience with them.
What I meant by fatigue is that because of the properties of aluminum
(expansion, stretching, etc.) the strength of the rod degrades over
time and it will eventually break. They aren't good for engines that decelerate
under load (like in downshifting), because that tries to "pull" the rod apart.
This is why they are not used in road racing or endurance racing, only
in drag racing, and the racers change them frequently.
Also, because of the stretching and expansion, you have to run more
"piston to head" clearance (which means a wider quench gap) and more
valve to piston clearance to accomodate the aluminum rod. One of the ways
to "squeeze" more hp from an engine is to reduce the clearance between
the piston and head at the quench area, and you can't do that as well
with aluminum rods.
You also have to run a little more rod bearing clearance, again because
of the properties of the aluminum. This is not condusive to a realiabe,
long running street engine.
The other problem is they are very bulky (albeit still lighter than steel).
This extra bulk means you have to grind clearance in the block around
the pan rails and bottom of the cylinders. And since they are much lighter
than steel, you'll pay more to get the crankshaft balanced because it
will require more work.
Admittedly, it's very difficult to be objective when selecting engine parts
for a new combination (I have the same problem). I'm building a new engine
for my '85 and am using 6.0" Crower steel rods, and they are very "pretty."
Check it out:
http://home.austin.rr.com/dancurrie/ProjectVette.htm
It might be wise of you to call C&A, tell them what your objective is, and
ask them about running their rods in a street engine.
Dan :)
