Quote:
If you did not have your block 0 decked, they will never be to 0 deck height. They will get to be at TDC though. You have to add the deck height at TDC to the equation. Most likely you will have to install the piston to find out this exact measurement. You probably don't want to use a Impala head gasket. Just stick with the standard height gasket.
Yeah, I figured i'd have to measure it. No, I'm not going to use an Impala headgasket. hehe... I remember the stories from .. ohhh. who was it.... that did that....
