Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-08-2002, 07:18 PM   #1
honaker
CF Senior Member
honaker's Avatar
Default Heads for a 350.
I'm going junkyard scavaging this week end. Looking for some brackets and what not. Maybe I can find a junk yard jewel. Anyway, question is, I'm going to be keeping my eye out for a good set of heads for my SB 77 vette. I currently have a set of smoggers on it. Problem is, I wouldn't know a good set of heads in a juckyard if they had a neon sign over them. Can you guys give me some pointers as to what to be looking for?
honaker is offline   Reply With Quote
Old 01-08-2002, 07:30 PM   #2
ORVette
CF Senior Member
ORVette's Avatar
Default Re: Heads for a 350. (honaker)
I am running a set of 5.7L heads off an '89 Pickup. They're nothing special, but they have 1.94/1.50 valves and 64cc chambers. Picked them up with a fresh rebuild and Z28 springs for $200. They don't perform as well as vortec, but they worked with my existing Performer manifold after a little modifacation to the center two bolt holes on each side of the carb. They're tapped at a steeper angle than the usual xx-'85 castings, so the manifold had to be notched on these holes to accomadate. Sorry I don't have any casting #'s handy. They're a great, inexpensive way to bump compression over 76cc castings. Happy hunting!
ORVette is offline   Reply With Quote
Old 01-15-2002, 01:06 AM   #3
Jason628
CF Senior Member
Look for 882 casting heads..they are pre-86 style and can be modified in a lot of different ways for not a lot of money! Plus they are cheap to obtain, which is a plus in my book... :cool:
Jason628 is offline   Reply With Quote
Old 01-15-2002, 03:44 AM   #4
glen242
CF Senior Member
Your '77 should have 882 (Smog) heads as factory installed. I was told 882 was prone to cracking.
glen242 is offline   Reply With Quote
Old 01-17-2002, 01:42 PM   #5
honaker
CF Senior Member
honaker's Avatar
Default Re: Heads for a 350. (glen242)
Yes, the are prone to cracking. They are fine if you leave the engine alone, however, i would port the heads , run a wild cam, or do anything to boost cylinder pressure, or run the engine reaaly really hard. That why i'm looking to replace them. I found a set of 993 for $100 that i'm picking up to replace them. :smash:
Reload this Page Heads for a 350.
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
What are valve stem seals for a 350 Chevy? Dalannex C3 Tech/Performance 12 04-05-2002 08:43 AM
Headers for a 350 with Angled Plugs for an '88 notbob C4 Tech/Performance 11 03-23-2002 09:10 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
