Well it's a rainy Friday night here, what else do I have to do
c66vet, I ran the spec's you gave in EA-Pro, with some guesses....
1.7 rockers
"EZX Isky Lifters" if I remember right, these are solid rollers?
Cam Intake centerline at 108 deg (4 deg advances - pretty typ for a Comp Cam)
2 in dia x 30 inch headers with an 18 inch collector, open no exhaust
Belt driven water pump
For the Victor Jr, I used a single plane with 5 inch runners, ported out to the head port size (straight port no taper). Wilson probably will port it out with a taper .. I could do that one later.
I had all the head spec's already loaded (from the AFR site) for the 315cnc and 335cnc, but I set both to 10.8 compression.
I let the program pick the best spark advance for now.
Think that's it, ran both the 315 and 335 cnc heads ...
http://temp.corvetteforum.net/c4/iris//540.jpg
If you buy into this whole Sim, thing ...
It say's the CFM's hit 1000 at about 6250 rpm
The 335's don't add that much
