Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-08-2008, 10:43 PM   #1
corvette744
CF Senior Member
corvette744's Avatar
Default dart big m block oil pressure
Anybody familiar with the dart big m.New motor installing a mechanincal oil pressure guage.My old guage fit by the oil filter,the new motor dart says to tap in by the top of the trans-drivers side-1/4 inch npt.Well i hooked it up and 0psi.Any ideas-guage worked perfectly before new motor.
corvette744 is offline   Reply With Quote
Old 05-08-2008, 11:25 PM   #2
BLOCKMAN
CF Senior Member
Quote:
I thought it was a 1/8 pipe in back of the left cylinder head I maybe wrong but are you tring to prime the engine??
BLOCKMAN is offline   Reply With Quote
Old 05-08-2008, 11:33 PM   #3
corvette744
CF Senior Member
[IMG][/IMG]NO as far as i now its a 1/4 then a male 1/8th then the stainless line.The motor was just dynoed and that is were they tapped in at.So i just went along with were they told me to tap in at.You should not have to prime if it was dynoed and installed i n the same week -at least i dont think so.
Old 05-08-2008, 11:53 PM   #4
BLOCKMAN
CF Senior Member
That is 1/4 pipe there as I looked down in the shop and was going by a Little-M I sitting there and I would not think it would have to be primed if it just came off the dyno but it would not hurt anything.
Old 05-09-2008, 12:14 AM   #5
BLOCKMAN
CF Senior Member
The only thing you can do is pull the dist. and use a priming tool and see if you can build oil pressure with the priming tool.
Old 05-09-2008, 04:21 PM   #6
BLOCKMAN
CF Senior Member
I see you found the problem over on the Dart board and what did you find. ??
Old 05-09-2008, 11:02 PM   #7
corvette744
CF Senior Member
Im embarresed to say-i stuck a pen cap in the line to plug it when i tighten the line on it pushed it up.Stupid but easy fix so im happy.
Reload this Page dart big m block oil pressure
Tags
access, bblock, big, block, c3, corvette, dart, fitting, guage, m, oil, outlets, perssure, port, pressure, sale, system
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Finally got *A* track time! 427Hotrod Engine Mods 14 11-20-2003 02:47 AM
Finally got *A* track time! 427Hotrod C3 Tech/Performance 18 11-08-2003 05:51 PM
Finally got *A* track time! 427Hotrod C1 & C2 Corvettes 9 11-08-2003 01:11 PM
my 383 experience mikey C4 Tech/Performance 11 09-05-2001 07:48 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
