Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-30-2008, 04:04 AM   #1
lil_Mike
CF Senior Member
lil_Mike's Avatar
Default heads/cam question
ok well im swapping my crossfire over to carb. i got a set of vortec heads,and a decent size cam oh and i also have 1.6 rockers. someone told me that i mgiht have to change out the springs or something to accomidate the cam.
is this true?
heres my cams specs (take in mind i have the 1.6 rockers)
lil_Mike is offline   Reply With Quote
Old 04-30-2008, 09:23 AM   #2
mr.beachcomber
CF Senior Member
mr.beachcomber's Avatar
Default New Cam = New Springs
Anytime you install a new cam, it's a good idea to install a set of new springs matched to the cam's characteristics. Even though your new lift is only 0.4656" with the 1.6 rockers, be sure to check for coil bind after installing the new springs.
Hope this helps!
mr.beachcomber is offline   Reply With Quote
Old 05-02-2008, 02:40 AM   #3
Curveit
CF Senior Member
Curveit's Avatar
That sounds like an "antique" cam. Have you checked with Comp Cams or some other major brand company? See what they have in the 224 @ .050" range. Unless of course. you already have that one.
Curveit is offline   Reply With Quote
Old 05-02-2008, 08:32 AM   #4
GOSFAST
CF Senior Member
Default Cam/Spring Choice
That's a bit on the small side, lift-wise, for a 350" SB. The .050" duration is fine! Would use wider L/S, read below! You may experience some vacuum problems with the 108* L/S.
Would have much better overall performance with the stock "L-82" grind along with the 1.5 rockers only!
The L-82 would give some greater vacuum readings and work with the relatively low-compression I assume the '72 unit retains.
One more "positive" with the "OEM" L-82 is the effective lift (.450") at the valve without "help" from the rockers. The 1.6 rockers, adding some .030" lift, will place some slight add'l loads on the lobes! There's enough "grief" in this industry with "flat-cams" as it is now.
Thanks, Gary in N.Y.
P.S. For a "drop-in" spring for your present cam OR the L-82 you can get by with the Z-28/LT-1 singles, 110# closed and 300# open (depending on the lift). These springs (Associated #SS-943-7) will handle up to .500" (nominal) lifts!
GOSFAST is offline   Reply With Quote
Reload this Page heads/cam question
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
heads/cam question Rob P C5 Tech 10 05-26-2005 09:39 PM
Heads/Cam SPECIAL.... from HOUSE OF SPEED DARTH VETTER C5 Tech 44 04-21-2002 02:22 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
