Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-29-2008, 10:50 PM   #1
rithsleeper
CF Senior Member
rithsleeper's Avatar
Default Will my Oxygen sensor get screwed up with this setup?
87' C4, if I replace my Cat with straight pipe, and have Y-pipe cutouts infront of my mufflers, when I open them up will the oxygen sensor mis read?
I ask because I mounted a y-pipe cutout in front of my cat on my Cadillac seville and when it was open the computer just dumped fuel into the engine running it way too rich.
rithsleeper is offline   Reply With Quote
Old 05-02-2008, 01:16 PM   #2
94LT1VETTER
CF Member
94LT1VETTER's Avatar
Should be ok as long as you're after the first set of 02 sensors.
If you've only got one set of 02 sensors, then be sure your cutout is after the sensors. The tailpipe will draw a vacuum and mix fresh air in with the exhaust leaving the engine, causing bad reading and a/f corrections.
If you've got the 2nd set of sensors too, just get 02 simulators. All's they are there for is so the ecu thinks the cat/s is/are there and functioning properly.
94LT1VETTER is offline   Reply With Quote
Old 07-02-2008, 05:30 PM   #3
BLOWNBLUEZ06
BLOWNBLUEZ06's Avatar
Only obdII has rear sensors. OBDII began in mid 1995, so you are OBDI and unless you create a situation that allows fresh air to get to the O2 sensors, that is not your problem. When you say "dumping fuel" do you mean that it smells rich? When you remove the cats, you will smell the fuel. Sometimes a great deal.
BLOWNBLUEZ06 is offline   Reply With Quote
Reload this Page Will my Oxygen sensor get screwed up with this setup?
Tags
mods, oxygen, sensor
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
