Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-26-2008, 12:09 AM   #1
John A. Marker
CF Senior Member
John A. Marker's Avatar
Default Is your new block really clean?
I posted something similar in the C4 Tech section, but I felt it should also go here.
I am building a ZZ4 short block that came assembled with pistons, rods and crank. I pulled all these out to have it balanced. More information on the balance at a later date.
We I built my first 350 years ago, the machine shop told that even though the cylinder walls looked clean, to take toilet paper and wet it down with ATF and keep doing so until the TP was no longer black or gray. Well I did that with my brand new ZZ4 short block after I pulled the pistons. Black!! I didn't take pictures, but should have.
I got to thinking today that the lifter holes were probably in the same condition as the cylinder walls. Well this time I have a picture of the results! Here is a picture of a single wipe of the interior of the lifter holes with TP and ATF. I threw a couple away when I first started and then kept the rest for the picture. The one piece that is horizontal is the final cleaning results on one hole.
And this is a brand new GM short block! And you thought it was clean.
__________________
1985 Coup -ZZ4 balanced, LPE 74211 cam, AFR 180 heads, SuperRam base, runners & plenum, cut out air box, K & N filter, power coupler, 52MM TB, March pulleys, AFPR, Accel injectors, Walbro FP, 1.6 RR, chip by TJWONG, 160 stat, cut back plugs, 8.5MM MSD wires, Brute Thunder Coil, custom camber-brace,TRANSGO shift kit, 2400 stall converter, cross drilled rotors, SS brake lines, VBP camber rods, IAS Edelbrock shocks, custom crossover on exhaust, Magnflow cat, 3.07 gears, 13.2 @107.2 MPH in 1/4
John A. Marker is offline   Reply With Quote
Old 04-27-2008, 10:19 PM   #2
mr.beachcomber
CF Senior Member
mr.beachcomber's Avatar
Default It's Not Unusual. In Fact It's Normal.
What you are removing is the grit left over from the honing process that is embedded in the block - not unusual for a mass-produced block. Taking the time to remove this material before the engine is fired up is just another step in the custom engine building process. BTW, David Vizard recommends removing the grit from the piston bores in the following manner:
"If you want to reduce piston and ring friction and the time it takes to break-in the engine, try this for a torque-enhancing move. Use a Scotchbrite pan-scouring pad to polish the rings until they feel smooth and slippery to the touch. Next, use a pad on the bores in a vertical motion, and use Gunk engine cleaner as a lube. Continue the vertical polishing until the bores feel really slippery. This action takes out a minimal amount of metal and removes or smooths the microscopic tears left behind by the honing process. In effect, this process is similar to a fine plateau honing job."
mr.beachcomber is offline   Reply With Quote
Old 04-27-2008, 11:14 PM   #3
cardo0
CF Senior Member
cardo0's Avatar
Location: So Cal- - Defend your ideas with facts. Not personal attacks.
Default Spic and Span.
Hot water.
Spic and Span.
Soft bristle brush.
Scrub it until u can't see anything on a clean white cloth wipe.
Then protect it with ATF.
Hope this helps ya,
cardo0
cardo0 is offline   Reply With Quote
Old 04-29-2008, 11:09 AM   #4
cuisinartvette
CF Senior Member
St. Jude Donor '05
Nothing to worry about providing there arent any metal chips in there. Any type of dust cast iron related will be black.
Recently flushed out the water jackets on a Dart block and was shocked at how much metal shavings and large shards of metal I got out of there from the machine punching out the freeze plug holes.
Never assume its all clean, always double check EVERYTHING.
cuisinartvette is offline   Reply With Quote
Old 05-21-2008, 01:46 PM   #5
02milleniumrag
CF Senior Member
02milleniumrag's Avatar
Are we sure thats not assembly lube were looking at?
02milleniumrag is offline   Reply With Quote
Old 05-24-2008, 01:58 AM   #6
John A. Marker
CF Senior Member
Not assembly lube. I ran a clean finger around the hole first and where was not sign of color, just a light oil. When I pulled the thing apart for balancing, I never found any sign of assembly lube, just oil.
Reload this Page Is your new block really clean?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Corvette Parts News! New C6 Section! 8/28/04 CorvettePartsBob Ken's Newsletters 9 10-05-2004 12:23 PM
Took out my rods today. This is my rod bearings, dont look good :( [huge pics] devilfish C4 Tech/Performance 36 04-22-2004 05:10 AM
why spend the extra $ for a aluminum block ICULUKN-C5 C5 Tech 28 01-12-2004 02:02 PM
prepping the block for reassembly, how to clean it? mistaben C4 Tech/Performance 24 12-24-2003 07:50 PM
Observations and opinions about my new '79 Flareside C3 Tech/Performance 16 11-13-2002 04:21 PM
Big Block Update bence13_33 C3 Tech/Performance 34 05-10-2002 05:10 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
