Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-16-2008, 01:43 AM   #1
flynnd_33
CF Member
flynnd_33's Avatar
Default So u wanna guess?
So i wanted to see what all of you think my combo with make for hp/tq...and possible times....
Combo is
355
11.2.1 compression
patriot performance CNCd 195's 64cc
performer rpm air gap manifold
eldebrock 750 1407
bracket master cam 230/230 292/292 and 480 lift on I and E
1.6 rockers
stock rods/crank with 100 dome hypers....
and i have a superpower shot layin around....so if not quick enough have a 100/150 shot ready for it.....and its a 1980 L82.....turbo 350...3500 stall....and 3.70's...
so what do u all think?
flynnd_33 is offline   Reply With Quote
Old 04-20-2008, 10:19 PM   #2
korvetkeith
CF Senior Member
korvetkeith's Avatar
Send a message via AIM to korvetkeith
Quote:
Combo is
355
11.2.1 compression
eldebrock 750 1407
1.6 rockers
What do the heads flow?
korvetkeith is offline   Reply With Quote
Old 04-22-2008, 11:42 PM   #3
flynnd_33
CF Member
flynnd_33's Avatar
that should give u the head flow....i think there a very good bang for the buck...and try something new....
Old 04-24-2008, 02:26 AM   #4
korvetkeith
CF Senior Member
460hp assuming something like 110 lsa and 1 3/4" full length headers.
Old 04-24-2008, 07:51 AM   #5
SuperL98
CF Senior Member
SuperL98's Avatar
I ran a quick simulation on your combo, with what you posted.
Used Lunati #00010 230/230 .480/.480 109 LCA Hyd Flat?
Put 1 3/4 headers and a 800cfm exhaust (gave about 1.5 psi backpressure).
Anyway, I'm someplace that I don't have all my passwords, so I can't post you a graph but ... I get
481 hp @ 6000-6250
455 ftlbs @ 4800-5000
SuperL98 is offline   Reply With Quote
Old 04-29-2008, 01:36 AM   #6
flynnd_33
CF Member
flynnd_33's Avatar
481 hp @ 6000-6250
thanks super 98 for running that quick sim....and yes thats the exact cam that i have.....and i have the hooker headers...with side pipes...so pretty close....but yea thats alot better than i thought....how close are those simulations.....-20+ hp or what....now im just afraid of the rear...heard there quite weak....i hope this doesnt break it....might have to baby it a bit....and neone have guesses on what kinda times i can expect from this hp....off and on the bottle....thanks for the sim tho....
Old 04-29-2008, 12:49 PM   #7
korvetkeith
CF Senior Member
IMO, with everything optimized you might make that much power. However since most setups never are I geussed low.
Old 04-29-2008, 04:49 PM   #8
SuperL98
CF Senior Member
SuperL98's Avatar
I've done maybe 60 or 80 Sims of real cases, and if the data you put in is complete and accurate, the match usually is quite good to a real run on an engine dyno. The HP curve and peak is mostly right on, and yes maybe +/- 10HP at the peak. Chassis dyno runs (subtracting 12 to 15%) the Sim typically over estimates the low end power (torque), I have some theories on why that is
I have found the worst matches are with some magazine article, especially when they are trying to sell you something
If you can give me a better intake runner length and dia, and header pipe length and dia (those long side pipes will have an effect), I will run it again sometime and post a graph.
I did one for another forum member here, and it came out pretty OK ..
http://forums.corvetteforum.com/show....php?t=1985396
Quote:
Your guess will probably turn out closer than mine and it didn't cost you $500+ for a program .... experience is worth more than $$$$$
Reload this Page So u wanna guess?
Tags
00010, cam, lunati
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
[BG Speed Demon] issues at idle LiveandLetDrive C3 Tech/Performance 81 04-28-2005 10:35 AM
Guys, should I stop posting wholesale auction prices for you??? V8USA C5 Corvettes for Sale 70 11-24-2004 11:07 AM
the "typical vette owner"..... C5 KIDD C5 General 57 09-17-2004 12:29 AM
Now THAT is service..... ski_dwn_it C4 Tech/Performance 11 06-30-2004 01:39 PM
New best 1/8th mile today vette man 01 C5 Tech 13 02-10-2004 12:23 AM
HUD install...for those that wanna know (2 pics too)-----> Ram Air Tony C5 Tech 35 08-13-2002 02:03 AM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
