Corvette Forum
Go Back   Corvette Forum > General Corvette Topics > Engine Mods
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-15-2008, 10:40 PM   #1
John A. Marker
CF Senior Member
John A. Marker's Avatar
Default ZZ4 questions
Well, I blew a head gasket in October and haven't had the time to tear things down. With 235,000 miles on the engine I finally made the decision rather and just replace the gaskets to do things right.
I ordered a ZZ4 350 short block on Friday the 11th from Summit and it arrived today talk about a quick delivery. The other parts I ordered arrived the next day, Saturday the 12th.
The short block comes with pistons, rods and steel crank all assembled. You have to add cam, timing set, oil pump....etc. Most of what I have will transfer, but have ordered new parts as well. But you may not know that the ZZ4 is not balanced from GM . So I am pulling it apart to have it balanced.
That is the background, now the questions:
1) Since the ZZ4 is a new motor, can I use the old "standard torque values"?
a) connecting rod caps 45 pounds
b) main bearing caps 80 pounds
2) Is the retainer that holds the cam in at the front of the block torqued?
3) What about the rear main seal...any torque values there?
I am not too worried about the other things. I have torque values on the AFR heads and the SR. This will be a mild build, nothing radical. I will install the Lingfelter 74211 roller cam with 1.6 RR's. I have to change out the springs on the heads. My old 85 with the AFR heads and SR using the stock cam and pistons was at about 346 HP at the crank and 434 lbs of torque. I am guessing this new combination will be 375-400 HP and close to 500 pounds of torque. We will see what the numbers are when I have TJ Wong dyno and burn a new chip for this motor.
I posted this in C4 Tech and all I got was debate about balancing. I know that the factory does a half ass balance. My real questions have to do with TORQUE numbers. Any help is appreciated.
-John
__________________
1985 Coup -ZZ4 balanced, LPE 74211 cam, AFR 180 heads, SuperRam base, runners & plenum, cut out air box, K & N filter, power coupler, 52MM TB, March pulleys, AFPR, Accel injectors, Walbro FP, 1.6 RR, chip by TJWONG, 160 stat, cut back plugs, 8.5MM MSD wires, Brute Thunder Coil, custom camber-brace,TRANSGO shift kit, 2400 stall converter, cross drilled rotors, SS brake lines, VBP camber rods, IAS Edelbrock shocks, custom crossover on exhaust, Magnflow cat, 3.07 gears, 13.2 @107.2 MPH in 1/4
John A. Marker is offline   Reply With Quote
Reload this Page ZZ4 questions
Tags
85, balance, chip, corvette, tj, wong, zz4
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
-RANT- Garages jerking me around./May sell the ZZ4. Cookwithvette C3 Tech/Performance 38 05-20-2004 12:06 PM
One of a kind 1979 Corvette For Sale w/ZZ4 350 & 5-speed degbert80 C3s for Sale/Wanted 17 09-15-2002 07:36 PM
ZZ4 questions Cothrom C3 Tech/Performance 11 08-22-2002 10:32 PM
My ZZ4 is now home, and all I can say is ... mg62 C3 Tech/Performance 50 06-05-2002 09:43 PM
ZZ4 questions/issues: headers, water pump, fuel pump, radiator, distributor, carb ... mg62 C3 Tech/Performance 25 05-25-2002 07:28 PM
ZZ4 questions Sigforty C3 Tech/Performance 22 04-29-2002 05:46 PM
"A ZZ4 will not pass emissions......ever !!" BSeery C3 Tech/Performance 45 01-14-2002 03:31 PM
what will a zz4 do for my vette? andre77 C3 Tech/Performance 33 10-30-2001 03:46 PM
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
